Mikes Motor Build-up
Started by Mike D, August 24, 2005, 10:20:43 PM
Mike D
Okay as most of you know my motor blew up on my 87 runner. So I already bought the stuff to rebuild it and I'll post up some pics.
Here is the Dead block
Mike D
Here is the other side of the Block
Mike D
Here is the Donor Block i had layin around and it already has been hot tanked
Mike D
92mm Rocker pistons
Mike D
Dual Valve springs with titanium retainers  :drooling:
Mike D
Hard Chrome rocker shafts with extra oiling holes for High RPM :disturbed:
Mike D
For the extra torque I got the 261 Crawler RV cam
Mike D
I got the oversized Stainless Steel Valves Exhaust and intake
Intake .033 over
Exhaust .024 over
Mike D
And to get the power to the wheels i got the Ceramic clutch kit
Mike D
Then to top it off I got the 1600 lb. Pressure Plate
Skinny_Pedal
your :pokinit: aint got nothing on me :gap: (this is where the flip off smile would go)
Im an OG
Mike D
Well this exact motor kit from engnbldr.com has 143 hp at the rear wheels and i will be porting and polishing the head and installing a header so I'm estimating at least 160 hp
Heres a pic of what did it all it broke right in the middle
Mike D
I'm sending the crank, head and the block down to a mach shop to get the block bored, the crank ground and the head prted and polished and the larger valves installed.
Mike D
Here is the head I will use the only prob is that it got smacked by the piston and left an inditation so i may use the other one I got.
Mike D
I'll post pics of my new treasure and new assurance that this will never happen agian when the get here :yesnod:
Mike D
All I got done so far is the Rocker Assy.
CTENG in KS
Mike D
I dropped of every thing at the mach shop and the machine work will cost about 500-700 bucks :scared:
Oh and I gonna be building a full dash and here are my new gauges
Mike D
thebigl2005
Nice job Mike. Its Luigi. Why dont you wait till school and get help form patty boy, just kidding.
Mike D
Is that your toy in the pic or you still got the ford
Ramrod
did you just get the master engine rebuild kit from engnbldr or does he have a separate high performance kit.  is that 143hp from and r or re.  I think I am going to get the same kit for my 22r and someday convert it to injection.
Mike D
Quote from: bigbluewillys on August 28, 2005, 12:46:40 PM
that is 143 hp with all the performance stuff they offer and it was for a 22RE then you can port and polish the head deck the block and you'll be on your way to 160ish
Ramrod
when do you think you are going to be done with this motor?  I want to see how fast it is.  I cant last much longer going as slow mine is.  I had to go in third gear up alot of the hills going to the con this weekend and everyone I was with smoked me.
thebigl2005
Quote from: Mike D on August 28, 2005, 12:30:44 PM
i still got the ford, seeing as pat mad me take it home as is and wouldn't help me with it. I thought you knew i got an 83 pick em up. Yea when you get this project done you should hit me up to go Wheeling.
Mike D
Quote from: bigbluewillys on August 28, 2005, 01:00:59 PM
The motor will be done ina week but the truck won't be done for a while
h0nke
lookin good mike ;) .... what brand gauges are those?
hurry and and build your dash already .... i want to see how it turns out.
1980 SR5 shortbed pickup (Project Rust Bucket)
Mike D
the gauges are auto meters amerincan platinum series but the only prob is tha tach they offer that looks like the other ones only goes to 7k :(
h0nke
i get to pick up my 86 on Sunday  :beerchug:
Mike D
I've been really busy but with the port job that i am doing i will have 187 hp at the rear wheels :o
