Mikes Motor Build-up
Started by Mike D, August 24, 2005, 10:20:43 PM
Ramrod
toybuilt
1983 Toyota Turned Chevy
t-tenkid
if youv already got that much into it go with the dual,less tchain streach more relable. whats the rest of the rig gonna look like.
To The Floor
go with the dual timing chain with the steel guides.
Mike D
The final bit of goodies to buy:
dual timing
larger injectors
lc header
nology hot wires
denso iradium plugs
I also did the little mod to the mass air flow by moving it five teeth to get a little more gasoline in the gasoline sucker
Please hold the drool
Mike D
Arp head studs :drooling:
Quote from: Mike D on October 04, 2005, 07:44:35 PM
i think you are going to slap me but i dont think i will for a while unless you think it is completly nessesary to do now. since you are the motor man around here its all riding on you wether i buy it or not :dunno:
:slap:  all those performance parts and no cam :down:  trust me if you want your engine to give you the performance your wanting you have GOT to get a LCengineering .440 efi cam
http://www.toyotacatalog.net/m1webgear/ProductDetails.aspx?PartID=1022024&PartRevisionID=
20R/22R - EFI Pro Camshaft
Smooth Idle (1200-5000 rpm range)
Throttle Body, Filter Charger, 1 1/2" Header
                                            Intake     Exhaust
Valve Lash                              .008         .012
Valve Lift                                 440"         440"
Advertised Duration                  280°         280°
Duration @ .050"                     230°         230°
Lobe Center                            102°         118°
Intake Opens         13°   BTDC
Intake Closes         37°  ABDC
Exhaust Opens      45°  BBDC
Exhaust Closes       5°  ATDC
what im running
20R/22R - Stage 2 Camshaft
4WD / Pre-Runner / Hot Street 2WD (1500-5500 rpm)
Modified Carb or Throttle Body & 1 1/2" Header
                                            Intake     Exhaust
Valve Lift                                 460"         460"
Advertised Duration                  290°         290°
Duration @ .050"                     240°         240°
Intake Opens           18°  BTDC
Intake Closes          42°  ABDC
Exhaust Opens       56°  BBDC
Exhaust Closes        4°  ATDC
actually with being bored out and stroked its closer to the stage 3
Ramrod
Quote from: 79Coyotefrg on October 10, 2005, 08:13:42 AM
glen I thought you ended up going with a 22r head.
nope , 20R for the extra compression and air flow,
Mike D
i'll add it to the list along with the big bore TB or I might just do a custom one i have not decieded
Mike D
Oh looky Mr.test pipe 8)
Ramrod
that thing is bad ass where did you get that.
Mike D
ebay for 56 bucks it isfor the 2nd gen runners
Ramrod
thats just a pipe that is supposed to look like a cat right.  I just got a bad one for free from a smog shop that fit my truck perfect for free and hollowed it out. It's like and expansion chamber
Mike D
it looks just like the inside of a glass pack
Skinny_Pedal
Quote from: Mike D on October 09, 2005, 11:03:08 PM
i would wait to play with the afm till the motor is running. that thing is touchy. i had mine running to perfection re-sealed it. then get out here in wyoming and need to play with it again. the build up looks great, you will love the power, it truely is night and day.
Im an OG
h0nke
alright mike! the engine is lookin nice man. post a price list of this overhual so far including parts/machine shop labor. oh ya, how much oversize are the KB pistons compared to stock? thankx :coffee:
1980 SR5 shortbed pickup (Project Rust Bucket)
SWAMPER
Quote from: Mike D on October 04, 2005, 08:19:21 PM
i was alos wondering if anybody here was running a tb spacer cause ther is a new guy who offers them for 75 bucks shipped and he claims they add 8hp and 2-3mpg :dunno:
Where at mike....i have acesability to a dyno so i can aquire that part dyno and piss on the guy if its BS
