the small arb compressor..
Started by Brandon, August 19, 2005, 02:20:52 PM
Brandon
http://www.marlincrawler.com/arb_compressor.html
anyone running one? I got the caddy compressors and I got a powertank but for the price it might be nice to just get one of those compressors and be done with it.
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Brandon
Brandon Miller
Willy Mammoth
Dammit man I may wind up doing that to mine some day, I guess I need to make a snorkel for it before hand.
I am using the one that is for the air lockers and so far so good, but I have heard it won't last if you use it for pumping up tires.
Snowtoy
If you run a larger storage tank, the Caddy comp. will work fine.  I originally ran 3 of the Caddy comp tanks along w/1 Caddy comp.  This worked fine, I could get about 5-7 activations before the comp would kick on.  With all the fittings tight, the Caddy would come on about every 15 minutes.  I have since fabed up a 4"x8" tank(you can buy 1gal. tanks for about $60) cylinder and use it with the caddy comp.  It takes the caddy about 35 seconds to fill the tank, and I get 15+activations before the comp. kicks back on, and without as many fittings  the comp only runs about once an hour.
I fab'd up a unit for a buddy using a 3"x7" tank using a Superflow MV50 comp. from Kragen for his OBA and ARB's.  The little MV50 comp. run anywhere from $25(online), to $44(kragens, Pepboys, etc.).  He is able to fill his 38's from 3-15 psi in about 35-40 minutes.  I am also using one of the MV50's as well to feel my tires, with a 2-2gal tanks, it takes me abot 45 minutes to fill my 33's from 3-35 psi.  I run both comp.'s and the 4'x8' tank in a box in a 27'x9"x14" box in the back of my truck.   If you aren't limited by space, the Mv50 is a good deal for the price.
Brandon
I have a powertank, this is strictly for the ARB's.
Brandon Miller
