Author Topic: Auto to manual tranny swap  (Read 3904 times)
gturismo
  • Turtle Points: -20
  • Male Posts: 327
  • Member since Oct '04
« on: Aug 14, 2005, 08:09:10 PM »
Well I finally got all the parts rounded up for the swap.  Okay, I have 98% of them, and that's close enough to get things started.  I started by disassembling one of the transfer cases for the crawl box.  I found I could do everything at home except press the bearing off the main shaft.  I had to take it to a shop.
I wasn't sure if I wanted to attempt this myself, but it was really quite easy.
« Last Edit: Aug 14, 2005, 08:32:58 PM by gturismo »
85 Runner
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
Re: Auto to manual tranny swap
« Reply #1 on: Aug 14, 2005, 08:11:04 PM »
please post pics of the pedal mounting, slave cylender stuff...good luck! :qtip:
gturismo [OP]
  • Male Posts: 327
« Reply #2 on: Aug 14, 2005, 08:16:44 PM »
Next was the assembly of the crawl box.  This was pretty straight forward as well
85 Runner
gturismo [OP]
  • Male Posts: 327
« Reply #3 on: Aug 14, 2005, 08:19:44 PM »
I'll try to get some shots of that stuff.  That will be towards the end, unless I get bogged down somewhere and need something else to work on.
Next was bolting on the other transfer case
85 Runner
gturismo [OP]
  • Male Posts: 327
« Reply #4 on: Aug 14, 2005, 08:39:09 PM »
I ran into my first problem tonight.  The rear tranny seal in my kit appears to be the wrong size.  It's just a little bit too large.  It's loose on the shaft and it will not fit into the tranny housing.
I decided to get the auto ready to pull.  I got everything unhooked, disconnected or removed with the exception of the top driver's side tranny bolt.  Man, that thing is a @#&%$! :mad: .  Anyone got any tips/tricks for removing it???
85 Runner
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
« Reply #5 on: Aug 14, 2005, 08:44:32 PM »
Put a jack under the transfer case or tranny and un bolt the transfer case crossmember.  Let the tcase drop a few inches to gain some clearance.  Use a 36" long 1/2" drive extension with a 17mm socket/ujoint on the end.  If you've got an impact wrench that'll take it right out.  Without an impact, you'll need a buddy to help you steady the extension and you'll have to tug on a breaker bar.  A grunt and a fart later it should be out.   :beerchug:
What year is your rig?  Is your auto trans electronically controlled, or older than that?
Ryan
gturismo [OP]
  • Male Posts: 327
« Reply #6 on: Aug 14, 2005, 08:52:53 PM »
Ryan
Hey, thanks for the tip!  I was using the long extension and ujoint combo, but it was 3/8" and the extension was twisting.  I need to go buy a long 1/2"
It's an 85, A340H (electronic)
« Last Edit: Aug 15, 2005, 10:57:54 PM by gturismo »
85 Runner
furbis
  • Turtle Points: 39
  • Member since Jul '05
« Reply #7 on: Aug 15, 2005, 11:29:29 AM »
Quote
I can try and take some pics of my donor truck tonight if that would help.
fellowsped
  • Male Posts: 23
  • Member since Jun '05
  • sh*t or get off the pot
« Reply #8 on: Aug 15, 2005, 09:46:23 PM »
you could cut a little hoel in your floor to get to it. had a buddy that did it and if you're carefull when you're done you can just bend it back down (there will still be the cut but you can bend the floor back down) and put the carpet back over it and call it good.
remember no matter how bad life gets there's always beer.
money is for rich people
85 toyota p/u, lincoln locker rear, debating on lincoln locker front, 22r desmoged, 31 bfg a/t (worn out but came with truck), the plan; 35 super swamper boggers, duel t-cases, buggy leafs, crossover steering, internal roolcage, rocker bars, a winch, and a few other little things.
gturismo [OP]
  • Male Posts: 327
« Reply #9 on: Aug 15, 2005, 10:57:01 PM »
Made a little more progress tonight.  While waiting for my help to arrive, I got the cases bolted to the W-56
Had a couple pics but can't post them.  It said something about the upload folder being full and to contact an administrator.  Oh well, I'll try again tomorrow.
Also finally got the auto removed  :greengrin:
85 Runner
gturismo [OP]
  • Male Posts: 327
« Reply #10 on: Aug 15, 2005, 10:59:36 PM »
Thanks for the suggestion, but we got it :beer:
85 Runner
Last post Dec 14, 2004, 08:57:25 PM
by reklund5
Last post Feb 25, 2008, 04:37:52 PM
by Teamsobaco
Last post Sep 27, 2006, 02:49:50 PM
by johnnygalt
Last post Nov 22, 2008, 09:25:27 PM
by x2nou
Last post May 29, 2010, 12:51:31 PM
by chim
