will a V6 detroit work in a 1st gen 3rd w/ stock gears?
Started by rEdnECkwHeE1eR, August 13, 2005, 11:26:56 AM
rEdnECkwHeE1eR
I bought a detroit from someone for $50  :king: (they said it was bent :headscratch: which i doubt) anyway a little while after I bought it I rembered that it was in a V6 3rd member :smack: so...
How do I tell if it is actually a V6 detroit and they didn't just stick a 4cyl one in there, if thats possible :confused:
And....If it is a V6 carrier can it be used in my 4cyl 3rd?
help :shudder:
Liquor up front
Poker in the rear
Willy Mammoth
I think the only differance is the bearing size for the carrier, they are larger on a V6 & high pinion. I am sure you can use it with 4 cyl gears in a 4 cyl third so long as you use a special bearing set that Marlin sells. Get a second opinion before you go down that road.
rEdnECkwHeE1eR
Liquor up front
Poker in the rear
mcfly
It will work, you just need to buy 2 timken bearings, part number 32010x.   :thumbs:
