my rig"bernice"
Started by BONER, August 08, 2005, 05:57:26 PM
eddyb
I thought that you had blown the motor?
On a lighter note.  Went wheelin' today down in Washington county.(it's good to be the President)  It was a typical day,  Cut some trails, blew my front dif, flopped a jeep on it's side.
http://img.photobucket.com/albums/v238/eddyb/DSC00587.jpg
http://img.photobucket.com/albums/v238/eddyb/DSC00586.jpg
A bad day of wheelin' is better than a good day at work
Stinky
hell ya man!!  im soo pumped...
damn ed, where the hell is that at??
87 p/u SAS, 22RE, built, then cut up and scrapped
94 ex cab P/U, SR5, fully loaded, 3.4 swap, r150f, a/c, bumpers, 33s, glass fenders...sold
00 Stoopid Duty 250, ex cab, lariat, v-10,000
94 reg cab, 22re, duals, 38.5 boggers, sas, 4 link, tube bed, build underway... http://pirate4x4.com/forum/showthread.php?t=967836
88 Samurai, soa, buick 3.8, th350, zuki case, 1/4 done... anyone wanna buy it??
MudSlinginYota
nice job on yerr frontend there Ed lol. how did you do it?
it looks like he could have drove out of that if he had closed diffs
1986 toyota 4runner http://board.marlincrawler.com/index.php?topic=61257.0
1997 dodge ram 4x4 (for sale)
eddyb
he was locked.  winched it upright and drove it out.  I was already busted when that happened.  As for me, a hard left turn up over a berm and a quarter of a million miles.  Can't wait to open that case up.
MudSlinginYota
i knocked some teeth off my ring with only like 17k miles on the truck, yea i guess im hard on my truck  :sly:
http://www.4wheelparts.com/Store-Info.aspx?sNo=211  thats right ladies... 3 mins from my house  :yesnod:  opens saturday and scott and i get us a free tow strap for been there when it opens
Stinky
Quote from: MudSlinginYota on October 31, 2007, 11:21:57 PM
ya they give you a strap so you can get your stock heep pulled out then take it there so they can bolt every chrome thing you could ever imagine to it.....
Stinky
welp, i talked to the old man yesterday and his suggestion was a 90-95 runner...... cuz i can find one with a blown up 3.0 to rip out n drop the 4.3 in....
so i go on here and pirate and search around.... not much, BUT, i saw a few t100 builds... their rare, and i like that, so looks like im searchin for a t100 now.... ill prolly end up usin a gm 10 bolt or a pass drop 44.....since its a little wider than the stock toy axle.... but im gonna start a thread on here n pirate for some ideas....
i might just run a th350/241 or 248 case...temporarily... BUT it all depends on how the motor is in whatever truck i find.... cuz some have the 3.4....... we'll see...
Stinky
MudSlinginYota
that truck looks nice. i like the color and setup. maybe you should have a front clip on yours though... just a thought.
Stinky
haha ya, well i searched autotrader for em.... like findin a needle in a haystack...
i gotta do somemore homework on em.... their a bit wide for my axles... but we'll see...
theres a 85 p/u on Paragon's forum, 305/th350/205, stock toy axles... whole truck $1k.... and the pics of the body are SOLID... i had my roommate from last year send him a PM with my email n my info, so hopefully he'll get back to me.. if the frames solid, sold... if not, i might still go for it..... i mean its a truck, another SFA and a 1 ton driveline for a grand....
MudSlinginYota
hey stinky give me some instructions on welding my rear spiders the right way. amps,rod,hot or cold,what to weld, yada yada.. im tired of been open, no money for a locker, and nobody makes spools for the 4cyl taco axle.
or if anybody knows of a good pic by pic website
even though lincoln lockers are half ass i dont wanna do it half assed
Stinky
#1391
Quote from: MudSlinginYota on November 03, 2007, 08:25:43 PM
you cheap A$$.... well here she goes.....
1.  pull the third out
2.  pull the carrier out
3.  pop the ring gear off
4.  brake clean the piss out of the carrier(you want all the gear oil and
     any oils OUT of the metal)....see if you can find someone with an old oven, n leave the pregnant dog in
     there for an hour or so at like 400, that'll boil the oil out of the pores
5.  then use a 1/8" E7018 stick rod(you wanna use this rod cuz it has a substantial amount of nickel
     in it)...or if you can get nickel rods off someone or even buy em, run around 80-95 amps
     you'll want a rod high in nickel, since the carrier is cast
6.  then while its still hot(gotta weld cast while its pre-heated), just weld the spiders to the carrier,
     and weld the spiders to the center pin... and since your re-heating the center pin(which is
     already heat-treated, you will want to cut some piece of 1/4" plate to fit in the little windows
     on the sides of the carrier to tie the sides of the carrier together(in case the carrier were to
     crack, the plate will keep it together.
7.  just make sure you keep everything hot while you weld on it, try and control the heat in the
    carrier too, cuz if it gets too hot then it'l warp the ring gear mounting surface, then once your
    done welding it, keep it some where it'll stay warm for a while and
    that it takes a good 3-4 hours to cool down.... cuz if it cools off to fast, you'll have a :pokinit: load
    of subsurface cracks inside the cast, then when she gets torqued hard enough,boom!!
8.  once its cooled off completely, you might have to do some clean-up to the ring gear will fit back
     on, since i know you'll cover it with boogers....
not alot of people take their time when welding diffs, but if it's your only vehicle, that you drive
everyday, then do it right the first time.... then have fun destroying tires!!!  haha, you'll get annoyed
after a while of it CONSTANTLY scrubbing, around EVERY corner.... and parking lots on warm days, haha,
prepare for a ton of people watching you park.... cuz your gonna be squeelin allllllll the time....
ENJOY!!
BONER
wow stinky that is the most intelligent thing u have ever typed nice job
93 toy extended cab, chevy 305,sm465 tranny with 6.39:1 first gear, np205 transfercase ,lincoln locked v6 third in front,marlin sas ,4 link out back , bonerbuilt bumpers and paint,37"SSR's, generic steelies, 16"bed bob,fuel cell,bonerbuilt roof rack, square front driveshaft,95 prelude seats,sparco harnesses,bedlined floorpan and lots of mojo.and some shiny new things.
Stinky
haha i try...... guess school REALLY IS payin off... haha
now if i could just hone my "getting laid" skillz....
wait, nope, nevermind, just had a freshie last week :ha_ha: :thumbs: ..... it twas niiiiiiiiiiiice :greengrin:
BONER
Stinky
BONER
well are you going to get another truck, or  keep driving the camry and put a fart can, some neons and a big subwoofer in it. you also may wear your hat sideways now that u are a ricer. or buy that runner u sent pics of.
Stinky
haha naww..... too much body rot..... after i sent ya pics, i crawled under it..... NOOOOPE
but i found a lot of posts on pirate about puttin my cab on frank's red truck.... so thats the gameplan..... and i can use my motor for the time being.... then when i got everything together, throw the 4.3 in it..... if i do.... i might just get case gears...
but i wanna fix the rear main, and put a stock manifold on it... n hopefully it'll make it back to williamsport.... cuz my dad wants the camry, cuz he's stuck drivin the green truck everyday.... and that car doesnt go anywhere when im here, so no point in havein 35mpg, when i dont use it... and the old man could use it....soooo my plan is to drive it till x-mas break, then swap the cabs/SFA over break.....
BONER
didnt u walk the crank in that truck???
irishracer34
i still love lamp!                          :willynilly:
irishracer34
Who wants to go out wed night.  Im going to be home Wednesday and im in the mood for a Lil :beerchug:.
marky mark
holy crap my account still works. well time for updates niiiiiice. picked up a 93 2.3l automatic 2wd ranger for $300. bad tranny, solid body. sooo everything came off of what was left of the 87 and now the 93 is a 4wd 5-speed.  its a sweet little truck.  i'll get some pics up tommorow for u NC bitches and yes adam it has a pappy cap on it too haha.  and i finally got a set of 79 bronco radius arms so i gotta fab some :pokinit: up to make them work, then i might actually have a flexy front suspension so i can bust out some mad jdm vtak :pokinit: on them rocks ya heard.  And i picked up a new set of wheels for the accord, jap-spec headlights and corners and a complete 5-speed swap for it too. fart cannon engage!!! haha peace.
93 ranger. Dana 30 SAS with radius arms and coils in front. 8.8 ford posi rear. 35" mickey thompson baja claws. 4.0 V6 with BBK supercharger. 6 inch superlift suspension, . Hella lights. and a T-handle shift knob made out of a Toyota center pin and spider gears.
BONER
beer&wed=good, stinker you got any toyota wheels@ i need xtras 4 the burb. and welcome back harry. happy thanksgiving.
Stinky
yes, tonight down otto's is gonna be pretty wild....
and shane, if you woulda called me about 9 hours earlier yest, you'd have 4 chevy wheels in your hand....
Stinky
yaaaaaaaaa buddyyyyy..... looks like im gonna HAVE to find a job for my x-mas break... finally found wat ive been lookin for... ill just have to paint her another shade so frank dont get mad haha................ just make a weekend out of it, and stay at my sister's place in columbus on the way back or somethin....
http://dayton.craigslist.org/car/453120972.html
BONER
MudSlinginYota
Stinky
thats wat im think thinkin, fire red... CHYEA
the guy hasnt emailed me back yet, buuuuuuuuut, i might have found frank's 99 runner... some dudes sellin a rolled 99runner, black n everything he's sellin is still good.... which was good on frank's... he wants to part it out... but im tryin to get it whole from him.....
their both in ohio, so hopefully by the time i get home for x-mas break, one of them will make a deal with me.....so we'll seeeeeee.........
furrballs95
hey whats up guys, me, mark and our buddy mike bruce went out and did some wheelin sunday night.  lets just say we all got are fair share body dammage :hammerhead:. it was supper slick and we were all bouncing off the trees. mike bruce  has his yota stuck to the point of lockin it up, but with marks expert spotting :rofl2: we got him out.  all in all it was a good time. :beerchug:
95 Toyota p/u 3.0 v6. Marlin SAS with 5"springs, 30 spline bobby longs, and a welded V6 third in a trussed 85 front axle. 529's front and rear, Marlin rear kit with 5" springs, lockrite rear locker,  36"  IROCKS on 15x10 black rock crawlers, custom front and rear bumpers,
Stinky
