What vehicles come with 60's???
Started by awhotrods, August 04, 2005, 10:07:24 AM
awhotrods
Like the title says, what vehicles came with a pass drop 60 front axle and center rear?  Is there specific years that are more desirable than others?  I really haven't used 1 ton hardware before, but considering it on my next project.  Thanks!  :beerchug:
crawlerdan
chevy one ton 4x4s came with pass drop 60s and 14 bolt rears, early dodge 1 ton 4x4s came with pass drop 60s, and 60 or 70 or 80 rears, depending on dually or deisel or big block v8 ect.- really- the older(late 70s and 80s) the axles, the easier to work with and the cheaper to  :wave: build
MiniSimp
awhotrods
*FFC*
:drool: dana 60's :drool:
:psss: even though neither of the ones you're lookin for are what I'm lookin for.  If ya happen to find a driver's drop in your searches shoot me a PM! :ladys-man:
RHG
Dont bother with newer Dodge drivetrain. I had a 97 1500 and I had nothing but problems with the axles. Rear was the chrysler though but it had c-clips=gay. They front was a 44 but ti was just a beefier verion of the heeps 35. I wore out axle seals like no other because it was a constant rotation axle. No manual hubs. I fried a u joint in the pass side real bad one time. A normal truck you just unlock the hubs and your good to go but nope, i rounded out the ear on my stub shaft soo bad that I had to tack weld the new u joint in. Its all crap I tell ya! :soapbox:
awhotrods
OK, so whats everyones opinion on which year, make, model, to yank a PASS. SIDE  DROP, front dana 60 out of???
toybuilt
I got my Dana 60 and 14 bolt out of a 87 1 ton chevy truck, the 60 has king pin nuckles which is what you want.
2021 Toyota Tacoma TRD Off Road
1983 Toyota Turned Chevy
Treat every day like its your last, because you never know when your time is up. In loving memory of Judstin.
4DEES
Quote from: rocks hurt good on August 06, 2005, 02:15:04 AM
well newer dodges also have driver side drop 60's.
and if you can get you hands on a set of 1tons out of a 80's military chevy that would be nice(front d60 with 4:56 gears and rear 14bolt with 4:56 also and a detroit rear  :drooling: )
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
freds40
IIRC Chevy started with the front 60 in '77 and used it up until '86. My Dodge front is out of an '85. If you can find one out of a truck from '80 and newer, it will have the non-neck down inner axles which are known to be stronger than the earlier neck-down shafts. Good luck and be prepared to  :moon:  as people who have them think they are gold. My first front 60 was a hook up deal of $500 about 4 yrs. ago. My latest was reasonable @ $850 about 1.5 yrs. ago. Now I'm hearing $1000 plus easily and more likely $1200-$1500  :yikes:
"between projects"
UNBREAKABLE
Quote from: YOTAon40s on August 18, 2005, 11:43:54 PM
They could possibly have a D70 HD FF rear with a detroit and 4.56's.....That is what I found with mine....I got a 60 Front,kingpin and 4.56's and a D70 Heavy duty full floater rear with detroit for a whopping $650 loaded!!!
That's how I roll
crawlerdan
toybuilt
I got my dana 60 and 14 bolt out of a 87 chevy 1 ton. It has 4.56 gears and detroit locker in the rear. It must have been a military chevy.
seanc
You win some, you lose some.
dj
I got a high pinion ps drop d60 out of an 1.5 ton jeep military truck with d70 rear for $350
it has 5.89 r&p. it also has some serious down sides to it like drum brakes A 6+ inch dia. hub I giant six lug pattern like rockwells and course spline axles, (maybe 10 spline, I don't remember.)
Toyota + Chevrolet = Toylet
82 toylet
400hp of birfield destructing fun
