SAS for a 86 4-Runner
Started by toyman2, August 02, 2005, 08:17:11 PM
toyman2
Is freaking orderd finally should have it friday or so
7m4runner
good luck with the swap!! If you can get your hands on a plasma cutter it will make the swap a lot easier.
RHG
speaking of plasma cutter...do any rental places rent those out? Like united rentals or all star rentals? When I do my SAS id like it to go as smoothly as possible and sounds like the plasma will help with that
7m4runner
i know u can rent anything from welders to sandblasters in our local area, it shouldnt be a problem finding a rental place, Renting a plasma cutter would be a wise investment for the SAS
gotrocks
i won't do it any other way than a plasma, so much cleaner and faster
trailhunter
Or you can become an Ironworker and get really good with a torch..............it only took me year or so to get good hahahhaa
TrackVino
I used a torch. It worked really good. Didnt have to do that much grinding.
crawlerdan
ive used a torch twice, and a plasma thirty somethin times, plasma leaves less cleaup, and is less dangerous around brake/fuel lines :flamer:  :yikes:
Plasma is way better.  I used a torche to cut all my stock spring mounts off when i went with a drop crossmember.  Took awhile and then i had to grind every bit of it to make it clean.  Plasma will leave it pretty clean by itself.
trailhunter
yeah a plasma is much much nicer to work with..............its just alittle hard to get your hands on.
toyman2
ill take what i can get when i get the parts im use to doing thing the hard way
