Be gentle, I'm fragile...
Started by Tice, August 02, 2005, 06:47:56 PM
Tice
So, I needed a new crossmember/skid plate for my 85, but I am cheap. So I decided that I would make one. :greengrin:  so after almost 4 weeks I got it on the truck. It really only took about 4 hours ::) . I still haven't started the skid plate. It will bolt up where the factory cross member bolts and sit just under the trans/t-case. I know it doesn't look that great and i still need to gusset the cross member itself. And fix my welder to finish welding the mounts to the frame. Oh and re-route the exhaust. So other than that what do you guys/girls think?  Also not sure how well the poly bushing are going to work, we'll see.
www.wheelingarizona.com
Tice
Crap!!! I think I put this in the wrong forum. :doh: :hammerhead:  Can someone move it!!???? :bowdown:
MiniSimp
Looks rather familiar.
I hope you used longer grade 8 bolts.
Tice
Quote from: MiniSimp on August 02, 2005, 06:54:09 PM
Exactly 3/8 inch longer!!! Same thicknees as the plate.
WHITE_TRASH
Nah this isnt in the wrong spot.  Its a drivetrain mod right?  It can stay here.  Looks pretty good, myself Id have bought the center from FROR for a whopping $54 or whatever it is now and built off that.  But there is something to be said about doing something yourself. ;)
Tice
Quote from: WHITE_TRASH on August 02, 2005, 07:00:22 PM
I did say I was cheap!!!! :gap:  I thought about that, but figured it would be a little easier just doing it all. :dunno:
WHAT?!  Are you frickin crazy man?  Sick maybe?  WT sayin he just woulda bought something rather than build it!!  You aint right boy!!!
WHITE_TRASH
Yea I know Im the guy that builds everything but the reason I do that is because most thing on the open market dont perform as Id like or are made differently than I would.  Thats why I build my junk.  But on something like that where Id get in a hurry and get the holes off and have to egg them for it to fit correctly its worth my sanity to just pony up the cash.  :talkingn:
crawlerdan
it looks like the one that i made, made mine with a laser cutter, and, um, i copied a budbuilt one, so.....looks good
Tice
Quote from: WHITE_TRASH on August 02, 2005, 09:19:27 PM
  But on something like that where Id get in a hurry and get the holes off and have to egg them for it to fit correctly  :talkingn:
how did you know I did that??? :greengrin:  I actually did have one hole off, so I welded it up and re-drilled the hole!! :beer:
Quote from: crawlerdan on August 02, 2005, 09:26:18 PM
How did you make the mounts on the frame? What did you use for bushings? Any pics?
crawlerdan
Quote from: Tice on August 02, 2005, 09:28:31 PM
i used 2.5 angle iron, and gm transfer case bushings as bushings at the frame, ill post pics tonight
*FFC*
Quote from: kneedownnate on August 02, 2005, 07:44:28 PM
That's what I was thinkin  :disturbed:
Tice
Quote from: crawlerdan on August 03, 2005, 06:34:34 AM
Pics would be cool man.
crawlerdan
Quote from: Tice on August 03, 2005, 03:14:29 PM
ill post em tonight captain impateint--hehehehe
crawlerdan
heres some pics for your veiwing pleaseure, what you are veiwing is dual cases with twin sticks, a 4.7 gear ihn the rear, a crossmember and skid plate that where made in a fab shop i used to work at :drool:  :drool:  :drool:
Tice
So I got the exhaust back together and fired it, (I actually left my C.B. on since last sat!!!, but the Optima was still holding charge :yesnod: )and the damn thing vibrates so much it'll make any girl happy!!!! :yikes:  I think I need to get rid of the poly bushing and go with rubber. Crawlerdan, what year and what trans( auto or manual) did you use? Thanks :beer:
Quote from: Tice on August 07, 2005, 10:18:20 PM
The mount I just modified mounted at the stock location but it was a little off and was touching the tunnel just enough to vibrate like crazy. Check to mak sure it is not touching anywhere and if it is move it down until it clears and if that is where the problem is that should fix it.
Tice
Quote from: Rocksurfer on August 08, 2005, 02:01:19 PM
It's not touching anywhere, I have some rubber bushing I'm going to try tonight. I don't really care about the vibration to much, I just don't like the fact the the mount has no flex in them. I'm worried that something will break when I'm in low with the monsterous touge output of the squirrel's trys to move the drivetrain!!! :joke:
