My runner blew a rod(with pics)
Started by Mike D, July 29, 2005, 04:04:08 PM
Mike D
I'm starting to hate this thing more and more everyday.I driving to work doing 3 1/2 grand and bang it pukin oil all over th place. so i towed it home and plunked the motor last night and there is a giant hole in the block from the #4 rod but not just on one side but on both side al the way through and down to the oil pan. the motor is supposed to have 65k  :rivers:
CTENG in KS
I'm sorry bro, I wish it was a girl blowing your rod...   :shakehead:
Mike D
 :funny: well here are the pics of the devastation and i schied9669 found a toy desiel that i am going to be putting in
Mike D
it almost went through the oil pan mounting surface
Mike D
Heres where the rod cracked
Mike D
It also contacted my new starter. I don't think shucks will take it back on warrenty :nope:
Mike D
Mike D
The cylinder came up and tapped the valves but the head and valves don't seem to be damaged
Duffil
its hard to tell from the pic, but did the rod split right above the cap bolts?
Mike D
it snapped about an inch up from the cap bolts
It took out the sleve and went up into the water jacket
Mike D
not only did the rod go through one side of the block but both and i don't see how that could happen at 3 1/2 grand unless my tack is way off :headscratch:
Duffil
i dunno man, you said the engine was SUPPOSED to have 65k on it?  maybe the rod was bad when they built it, or maybe it had way more on it...you should know how 3500 RPM feels in your truck anyway, ya know? If your tach was off, it wouldn't feel right.
Mike D
Yeah it a new tach and it did feel right and that is what i always pull that hill at
Duffil
maybe the rod was cracked and you were in it a little harder than usual, and she didn't like it? :dunno:
Mike D
The thing is it didn't make a noise before it blew it just gernaded all of the sudden
bmxanddie
*FFC*
Mike D
I get owned a lot :down:
I'm going to go and look at the diesel truck at the auto auction so i may be coming home with a new truck with 78k and a 2L for my runner :eyebrow:
luigi
85 4 Runner
22RE Auto to 5speed swap
Marlin Crawler Dual Ultimate Case
5.29s
Arb's front and rear
Rapidly denting away my "Mall Runner Status"
Good luck getting a 2l through smog.  You cant swap a diesel into a gas chassis if your in smog country.  Ahhh but I can on the east side. :greengrin:
Mike D
well I didn't win the truck it went for 1650  :shocking: and it had a bad t-belt and something with the fuel system was bad.
now i'm thinking of my choices of motors and so far I like the 327 the most
Why stop there?  If your going to scatter your drivetrain, and you will.  Do it right.  I have a 454 sitting here for $500 take it and shove it in there.
red
better upgrade ur front suspension if u do that tho.
read and comment :whip:
USAF EOD tech
Prismo
I have a turbo block in the yard that has an almost matching hole in it when compared to the last picture you posted. The rod broke in nearly the same spot.
RHG
Holy 22re blocks Batman! Bum luck man, just yank another junk yard motor and keep on going. Better yet, if you got the funds then yank two and start a slow rebuild on the other. You know, as $$ allows. Then you've got a spare
Mike D
I'm just gonna stick with the 22r I can get a pro rebuilt one with a 7yr/70,000 mile warrenty for 875 i don't want another junk yard motor considering how long that one lasted
Duffil
damn, thats pretty cheap...what is it, an Attarco?
Mike D
Its at a local machine shop called d&j machining :thumbs:
CTENG in KS
Is that already built and they are trying to unload it, or are they gonna put one together for you for that, cause that is a sweet price.  Even a rebuilt from Jasper or the like is around $1700.
kyle_22r
i'd just build it myself.  from all i've seen, the early blocks seem to have less problems with this sort of thing...maybe it's just a stouter bottom end.  though the '85-up are ALL the same(no main bearing differences like the '81-84 etc) but i've never had bottom end trouble on an early engine.  at least when you build your own engine you can be exactly sure of how everything is going to work.  not to mention building one of these is a snap
if its any comfort engnbldr sells sets of NEW forged rods(same as stock) for like $100 a set if im not mistaken.  i'd just get them balanced to the rest of the rotating assembly to make everything goes smoothly though.
