QUICK HELP.... '91 CHEVY VETTE ENGINE LT1 350 5.7l
Started by schlager_me, July 23, 2005, 10:33:10 PM
schlager_me
Is this engine a 2 bolt main or 4 bolt main?
It is in a FJ40 I am looking at with only two motor mounts. Even better, one is missing the bolt!!   :dunno:
Also, its missing the bottom half of the bellhousing on a turbo 400 trans. How much is this gonna run?
Thanks guys!
Wish me luck on my new rig!!!!!!!!!!
I don't know about the engine but the missing bell housing inspection cover is just a stamped steel cover. Should be easy and cheap to pick one up at a junkyard.
............and good luck on your project.
Crucial
well i dont belive they made a 91 LT1 but a 92 , and if its in a vette its 4 bolt main and if its in camaro/firebird/fleetwood/roadmaster its a 2 bolt main
stock 82 toyota 4wd
BUBBA
If it's a true 4 wheel drive th400 then the inspection cover is not just a stamped steel piece.The tranny will have threaded holes for bolts and the cover is cast aluminum with threaded holes for support rods that run to the engine mounts.There getting hard to find and you'll probably pay a pretty penny for it too.
My budget beater
4THEWKN
If it is a 1991 it is a L98 motor with alum heads (vette). If it's a 1992 then it's a LT1. Both motors 4 bolt mains. Either motor is nice............ Dean
Rock Rash: It's all mind over matter, if you don't mind it don't matter!!
Crucial
but if its a LT1 u dont want to soak it with water .... u will soon be puting a optispark in it ...
stock 82 toyota 4wd
Skinny_Pedal
we just pulled a motor out of an 89....its a 2bolt main :crazy:
Im an OG
CTENG in KS
Dude, those motors suck...you can send it to me I will get rid of it for you.
