85 truck lc motor swap
Started by Skinny_Pedal, July 23, 2005, 01:38:57 PM
Skinny_Pedal
well its time to put that lc engineering motor in my 85 turbo truck. what prismo and i are trying to do now is make this truck a non turbo. if i get a computer and harness can i still use my turbo intake parts? will the harness match up to the harness inside the cab of the truck? can i use the non turbo injectors in the turbo manifold if used with the non turbo harness? the reason for this is the truck did not have the original ct20 on it. it has a air reasearch m10 w/o a water cooling. so i want to switch over to regualr n/a. anyway here are some pics of our progress
Im an OG
Skinny_Pedal
 :thumbs:
Im an OG
unclejpl4x4
Skinny_Pedal
big bore throttle body and old motor. also have hi-flow injectors but there non turbo. like already stated i want to trade or purchase a complete non turbo setup in trade for my complete turbo setup
Im an OG
decyfer
sexy little engine. can't wait to see it in.
is it bad when you unplug the power wire from your stereo and it still plays
Ramrod
CTENG in KS
Damn, that some nice chit right there...I want one.
Skinny_Pedal
Quote from: bigbluewillys on July 23, 2005, 03:31:42 PM
why don't you want it to be turbo?
the truck didnt come with the ct20 on it like it should have. it has a garret t2 on it without the water cooling. my new motor also puts outs 9.8 compression so detination would be a biotch
Im an OG
Skinny_Pedal
anyway i got all the parts to make it a non turbo. i have a new lcengineering header(believe it is), complete 86 efi, harness and computer. got the lower intake on, motor mounts, and other misc stuff. robbing all the cool turbo stuff and put it on to, like the oil cooler :bling:. will get pics tomarrow. tomarrow finish bolting up the upper intake and harness, slap the marlin clutch on and set her in(the goal at least).
Im an OG
Skinny_Pedal
heres the specs on the motor . i also have the equalized injector set, big bore throttle body and kn f.i.p.k
2.5L - 135 HP @ 4,900 rpm
Extremely strong, predictable, low rpm throttle response
Perfect for 4WD's & 4-Runners
Very smooth idle
Here is a brief list of components in this engine:
Top End -
1021024  Street Performer Cylinder Head (85-95)
1022021  EFI Pro Camshaft
1023042  45.5mm SS Intake Valves
1023033  37.5mm SS Exhaust Valves
1023201  Street Performer Valve Springs
1023006  Street Performer Retainers
1023090  Hardened Valve Keepers
1023099  Toyota Valve Seals
1045030  New Exhaust Studs
1023018  Complete Rocker Arm Assembly
Custom Valve Cover (Red/Silver/Black)
Bottom End -
1011003  Pro Cylinder Block
1024069  Pro Head Stud Kit
1014343  94mm Pro Forged Piston Set
1013003  Street Performer Connecting Rods
1013048  Street Performer Crankshaft
1013072  Clevite 77 Main Bearings
1013132  Clevite 77 Rod Bearings
1013165  Clevite 77 Thrust Bearings
1016019  Brass Freeze Plugs
1015012  Dual Row Timing Chain Conversion Kit
Im an OG
To The Floor
decyfer
Skinny_Pedal
today is the day. more to come later :greengrin:
Im an OG
Skinny_Pedal
Im an OG
decyfer
crawlerdan
i got that motor in my runner, and i had the 2,6 strocker in my 85 crawler, sweet motors huh? youll love it on the rocks, and they are just as dependable as a normal 22re
Skinny_Pedal
i will get pics up like i said. the problem is with my 02 sensor. need to figure out how to wire it up in so mnay less words. also needs a non turbo afm but i already got that!
Im an OG
Quote from: Skinny_Pedal on July 31, 2005, 10:37:29 PM
Very smooth idle
Top End -
Bottom End -
i would be willing to bet your going to get more than 135 hp
crawlerdan
i have 145 on the same motor, and had 185 on the strocker :o  :eyebrow:
ok i just notice the "street performer " head,  but you'll still have a great engine,
Skinny_Pedal
thanks. i do plan on running it on a dyno after the break in. it sounded quite nice for a minute running the straight header
Im an OG
crawlerdan
only for a min though huh? then your head explodes :yikes:
eddybaboy
If you don't mind saying... what was the damage?  I want to do the same.  My head cracked :(
crawlerdan
mine was 5800
the second in my daily driver was 3700
worth every penny
Skinny_Pedal
$1100 in the crate still wrapped. i guess im just one hell of a shopper arent i :biggthumpup: .  o the truck has left prismos and is at the exhaust shop tonight so first thing in the morning that can get done. it sucked ass driving it 25 miles straight header. big thanks to nick(ttf) for heading out tonight and helping. but most of all prismo for taking on the swap and dealing with my crap :gap:
Im an OG
Skinny_Pedal
here are a couple pics of the motor almost assembled getting ready to toss in the truck. will take pics of it in the truck tomarrow. also i start the dash teardown for the efi harness in the dash..o joy
also anyone notice the old man hard at work?
Im an OG
blacktoy
eddybaboy
unclejpl4x4
So you done with my moter yet???            don't make me with hold your  :beer:  payments.  I expect that moter in my truck by  monday   or  :spankbutt:
Skinny_Pedal
so out with the old harness we go
Im an OG
