Speedo no worky
Started by KWP, July 20, 2005, 04:12:10 PM
KWP
 My speedometer stoped working today, it started yesterday on my way home from work. While driving it would work for a few miles then all the sudden stop and after about two more miles down the road it started working again. This morning on my way to work it was fine and now nothing. Any help would be appreciated. :help:
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
Rebeltilldeath3
Who needs a speedo anyways?
KWP
sounds like a broken cable
KWP
Quote from: 79Coyotefrg on July 20, 2005, 05:34:17 PM
are the cables interchangeable because I have one from an 85 runner?
RK
ya think broken?  poss came unscrewd?  not sure bout early 90's...
Max
Black Hole Racing - 84 Jackalope/79 Devil Bunny/87 Golf - Service rig: 2012 Ram 3500
If your cable is broken, I have successfully repaired two broken cables.
I ground each end where it broke down, and then welded the two back together, and then ground the welds down.
One of the two that I've fixed is in my truck right now and its working like a champ. I've max'd my speedometer a couple times at about 90 MPH (the 1st gens only go up to I think 85).
Here's a pic from my Project Thread, Page 19, Reply #562:
KWP
Quote from: BigMike on July 20, 2005, 05:58:52 PM
Did you weld it with a mig? All I have is a stick welder
KWP
 Well I crawled under my runner today to check my speedo cable and couldn't find it. Is it controled electronically on second gen runner sr5's? It has the a340h tranny in it. :help:
KWP
I think you are right, it is an electric speedometer. My brother had an exta-cab that he leased and we disconnected the speedo when he was about ready to go over the alloted mileage. If I remember it was just an electrical connection we uplugged. Turned on his check engine light when we did it though.
KWP
 If it is electronic, would I have to change out the guage cluster to run dual cases behind it? Inch worm just came out with an adapter to run a gear drive case behind an a340h  :clap2: . I know it is inchworm but I can still use a marlin dual case adapter. :biggthumpup:
I think the plug is on the left side towards the top side, it may have just come unplugged. :dunno:
robinhood4x4
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
KWP
Quote from: robinhood4x4 on July 25, 2005, 12:55:47 PM
speedo info: http://www.yotatech.com/showthread.php?t=13801&highlight=speed
Thanks man :biggthumpup:  That is exactly what mine is doing with the O/D off light. I guess its the speed sensor.I thought they were all cable operated. :dunno:
