header?
Started by kevs83yota, July 14, 2005, 12:35:47 PM
kevs83yota
What is the best smog leagal (in Ca.) header for a 22R?
One that provides the most HP.
My truck has no power.
any help is appriciated. Thanks
bigman
in montana they dont care
i like hooker and headman
MONTANA BOYS KICK A$$
IF U CANT DUCK IT F IT
Duffil
Downey Offroad makes a Cal. legal header.
Uncle Jesse
search, there are multiple header threads already.
4DEES
downey offroad is the way to go!  :thumbs:
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
toyota boy
i have a downey and its great
1985 4runner all pro 4" extreme lift, 35" pro comp mt's, downey header and cam
kevs83yota
toyman2
88-REDRYDER
killem en grillem
Skinny_Pedal
Quote from: 88-REDRYDER on July 18, 2005, 11:44:25 PM
go downey :yesnod:
only if you run a 3.0. otherwise the nwoffroad or lcengineering header is the way to go for us 22r guys
Im an OG
kyle_22r
i wouldn't run a 4-1 header like LCs on a truck unless i was building it as a street rig.  i bought a thorley, it was like $189+8.99 handling from summit.  looks like a nice piece, can't want to put it on :beerchug:
Uncle Jesse
note:
on the thorley header, keep in mind that the sealing surface (the welded O-rings) are not flush with the flange.  So if you use any of the three center studs, put a washer behind the flange to level it out.  Otherwise you will pull the center of the header flange down too tight (even with proper torque) and warp the flange.  This will make the header leak at ends.
