one big pain you're gonna run into is that you will find a connector from the dash harness to the taillight harness under the passenger seat. this ocnnector is different for truck as 4runners, so you'll have match the colors you need and pigtail/eliminate the rest. there is also a similar conenctor under the driver seat, same deal, but you'll need a lot less of the wires.
for the dash, use the oil sending unit from your 84 on the 92 block. if you try to hook-up the gauge to the idiot light sender, you'll blow the gauge out. Don't be suprised if you puug in the cluster and the gauges don't all work. there were two different mfr's of gauge clusters for toyotas, and the pin out in the connector may vary. you may have to get a machinist's pick and re-pin a few of the leads in teh connectors to get everything to work properly.
good luck!
