Tonka turning crawler!
Started by 6.72:1, July 05, 2005, 06:13:09 PM
6.72:1
Everytime I look at those hubs, they seem to get larger and larger!
This set-up is going to be quite the apparatus under my Yoder!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
6.72:1
You can also see that I threw in hardware in the back side of the hub (or the front depending on the way you have them flipped, but for me it is the backside) where the drum brake used to be.
I know the hardware wasn't necessary there, but I figured it would add to the medieval/ Roman army/ deathly look.
I like the studded look and the new hardware could double as spares if I needed some hub flange bolts as well, so I guess it was a cool idea.
[email protected]
6.72:1
Check out those grease cans! I had even more all over the place, but I just wanted to show the 1 pound little tubs I purchased. Yes, I was adding grease by the pound!
[email protected]
6.72:1
Here is the whole shot of the axle with the hubs on it.
[email protected]
6.72:1
I am at sixty-nine and three-eighths of an inch from wheel mating surface to wheel mating surface!
DANG THIS THING IS HUGE!
[email protected]
6.72:1
Here is a whole shot of the axle with the wheels I am going to run for a little while until I decide what tire/wheel combo I am going to run:
From edge of tire to edge of tire I am at a whopping ninety-two inches wide!
My brother measured somewhere around the width of his '87 second gen. from quarter panel to quarter panel approximately 66 inches. I may be incorrect on that, but that is what I believe he said.
With that said, I know the first gen. is not quite as wide and mine is really not as wide right now with the quarter panels completely off, so my cabin should tuck in nicely between the big, dumb, animal known as the ROCKWELL!
[email protected]
6.72:1
And somewhere in the mix, this ended up on my axle:
She is one of my brother's friends, but she asked if she could pose on my axle.
I thought it was hilarious.
[email protected]
6.72:1
I apologize for the sideways-ness of the photographs, but here she is again! If she was only around when I have to move this massive beast!
[email protected]
6.72:1
I believe these military tires are about forty-inches tall.
[email protected]
6.72:1
Oh, and as you can see, I got all new studs and lugnuts installed in the first few photographs.
[email protected]
6.72:1
In this photograph I just wanted to show how much stuff gets thrown in a bed, even if you have your bed off!
THE IRONY OF A MATTRESS IN A BED! HA!
[email protected]
6.72:1
Oh, and I got new shoes too.
What do you guys think about these Circas?
[email protected]
6.72:1
I will bring mack the sheer magnitude soon.
Hopefully this next go-'round I will be huge AND capable off road:
[email protected]
Yer brother needs his driver's license taken away man! :driving:
:cheese: 4 ½ lbs of grease per hub!!!!  :yikes:
Quote from: SHEER MAGNITUDE OF THE ROCKWELL on May 27, 2006, 12:35:34 PM
here she is again!
I would let her come over and um.....pose on my axle anyday! hehehe
6.72:1
Quote from: DirToyBoy on May 27, 2006, 01:50:15 PM
She is good company at times....
[email protected]
black92se
Being from south carolina, I cant keep from cracking up reading this thread.
1992 Pathfinder, cool stuff.
burnyota
don't see 18lbs of grease on em'
black92se
I think he is just trying to account for all of the grease that went missing when that chick showed up.
Quote from: black92se on June 02, 2006, 09:05:22 PM
:eyebrow: where did the grease REALLY go, Pete? Enquiring minds wanna know. A little off-topic but its still build up related haha
6.72:1
Quote from: black92se on June 02, 2006, 05:50:31 PM
Well, you understand then! HA! It just gets better every day! Everybody that sees that "HUGE APPARATUS" sitting in my garage is like, "What the hell is that doing there, what does it go to, and what are you doing with it?"
It is just hilarious.
Lately, the Rockwell has turned into a bench seat and more conversational material than anything else.
I promise I will get to work here shortly.
Well, actually, I have gotten a lot done to the truck and the toy axles, but I am just taking my time because I am waiting to collect parts.
[email protected]
6.72:1
Quote from: burnyota on June 02, 2006, 07:42:09 PM
Did, I say 18 ounds of grease? I meant 9 total, well there was some extra, but...it was put away.
[email protected]
6.72:1
Quote from: DirToyBoy on June 02, 2006, 09:37:00 PM
Actually, that is highly related to the build.
THERE IS SO MUCH GREASE IT IS EVERYWHERE!
[email protected]
6.72:1
I will have some update photographs for you guys a little later, so don't get discouraged....
[email protected]
6.72:1
I hope you guys and gals havne't given up on me yet!
Here are some update photographs:
[email protected]
6.72:1
Brackets Shackles cluster u-bolts
As you can see, I got the 'ol laser cutter to burn me out some brake brackets for the pinion brakes.
I was goofing-off and made some home-brew shackles while playiing with the "hole Punch" machine...HA!
I also got a newer cluster for my truck, but I am going to have to completely redo the dash because it doesn't fit where the first gen cluster sits!
As for the U-bolts, they are HUGE!
They are 7/8ths of an inch thick!
I do not believe I will be breaking those anytime soon!
Everyday, I seem to be adding to magnitude.
[email protected]
6.72:1
Unexpectedly having to buy one of these is irritating at times and tends to slow up the build process....
[email protected]
6.72:1
Now for some good stuff:
What you all have been waiting to see,
Calling BigMike...
[email protected]
6.72:1
Believe me, that thing is in there tight!
I am not going to have any heat, A/C, vents or any ventilation system of any kind.
Not having defrost should be fun!
[email protected]
6.72:1
[email protected]
6.72:1
I know it looks like the pulley is a bit tilted, but that is because it is.
I only had the motor mounts and transmisson/transfer case crossmember mounts tacked in and the left motor mount tack broke as did the right crossmember mount.
I had the truck at a friends and he only had a small 110 welder that was not very sufficient.
I was not familiar with that small of a welder, so that could be a reason for the tacks breaking, but don't be worried, I am getting near a larger welder soon.
[email protected]
