check out the specs(lift/duration and rpm usage)...you might be able to find a cam with the same range/power for less...as Clevite makes Yota cams...three stages, stock, 1 and 2...available from any NAPA or anyone who carries Clevite(DANA) engine parts...and if your gonna cam it, talk to the machine shop about getting your seat pressure higher...helps make a little more power!
