Need to know where these go
Started by Ferg, June 15, 2005, 05:20:37 PM
Ferg
Carbed '82 22R.  FSM does not show where the vacuum hoses for these two ports go to.  One is the Idle Up Diaphragm the other is just to the left of the throttle plate shaft.
derek
you got a third one below those also.  :hahaha:
derek
8D3TOY
Ferg,
  Just went out and looked on my '83 the diaphram connects to the top port on that gray colored vacume switch mounted on the fenderwell behind the battery. The one off the carb makes a short loop down to a small metal tube on the carb.  Its kinda dark so I'll look in the light with the air cleaner off tomorrow.
Quote from: derek on June 15, 2005, 07:54:50 PM
derek
I see one with a plug in it there too. :greengrin:
