22R bell housing
Started by fourwd1, June 07, 2005, 07:52:25 AM
fourwd1
Which, if either of these 22R bellhousings is for a 4WD tranny  ?.
Thanks
'80's Toyota 4WD P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH-350 L/U w/700R4 low gearing, dual tanks, dual batterys, other crap ...
- - - as seen in FOUR WHEELER magazine July 2006 - -
84 4Runner ARBed 5.29's F&R, 4.7 t-case, x-over, Chevy's, 2" drv train lift, 36" TSLs, 30 spline Longs, BudBuilt skid
notajeep
Truggy
im pretty sure its the bellhousing on the left thats whats on my truck anyways. :driving:
Building the CRUISER
b_ripper8
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
kyle_22r
2wd or 4wd shouldn't matter.  isn't the one on the left an R151F bellhousing and the one on the right a G/W series?
b_ripper8
both my 4X4 g and w series look like the one on the left. Never seen a R151.
the right side bell is a 2wd or L43,  but they were originally a 2wd tranny so :dunno:
toybuilt
I don't think that 2wd bell houseing are detachable, I do know that the one on the left is off a 4wd 4 cylinder.
1983 Toyota Turned Chevy
Uncle Jesse
Both of my 2wd bellhousings are detachable, and niether of them looked like the one on the right.  Mine were 83 and 89 celica and truck trans.
kyle_22r
ahh, that could be it.  L43s had a cast iron case and a removable aluminum bellhousing.  never took mine off though.
G, W, R and L trannies were all used in 2wd trucks as well.  most just had higher gearsets and a different tailshaft/housing.  as far as bolting up behind a 22R, they're all the same 2wd or 4wd.
Yup, right is definately a W or G series, and, I'm not 100% sure, but if it's a Toy belhousing, then it'll be a 4 speed L43.
Marlin
#11
Both of these 2WD bells will fit 4WD transmissions. However, I would not advise using them, because they are both light, thin cast versions that were not designed for the added weight of the t/case.
Left side, 9 bolt small pattern;
  81-88 G40 4 speed
  84-95 W45, 46 4 speed
  81-95 G52, 53, 54, 57, 58,  5 speed
  84-95 W52, 52, 55, 56 5 speed
Right side, 7 bolt dual pattern
  69-80 L40, 42, 43 4 speed
  71-84 W40, 42 4 speed
  71-85 W50, 52 5 speed
fourwd1
Quote from: Marlin on June 07, 2005, 11:00:57 PM
Thanks Marlin !
I knew at least one was from a 2WD. I was deciding wether to keep or trash (recycle).
crawlerdan
2wd bells are detachable aaron, remember, i had one that we took apart like 10 times :usa:
  81-88 G40 4 speed
hey Marlin a guy i know has a 89 with the G40,  can it be made into a 5 speed like the L45????
not that he needs it with the G662 diff,  seems like that was like a 3.07:1
Marlin
Yes 79Coyotefrg, the G40 can be upgraded to a 5 speed :thumbs:
cool,       i assume any G52/54  5th gear parts
