Author Topic: 22R bell housing  (Read 9795 times)
fourwd1
  • Member since Sep '02
  • Out On Bail
22R bell housing
« on: Jun 07, 2005, 07:52:25 AM »
Which, if either of these 22R bellhousings is for a 4WD tranny  ?.
Thanks
'80's Toyota 4WD P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH-350 L/U w/700R4 low gearing, dual tanks, dual batterys, other crap ...
- - - as seen in FOUR WHEELER magazine July 2006 - -
84 4Runner ARBed 5.29's F&R, 4.7 t-case, x-over, Chevy's, 2" drv train lift, 36" TSLs, 30 spline Longs, BudBuilt skid
notajeep
  • Turtle Points: -108
  • Male Posts: 703
  • Crawler #3289
Re: 22R bell housing
« Reply #1 on: Jun 07, 2005, 08:24:00 AM »
uh, Big Mike??  :help:
You have a Jeep?  That's cute.... So does Barbi.
Truggy
  • Turtle Points: 22
  • Male Posts: 143
  • Member since Apr '04
  • Hammered
« Reply #2 on: Jun 07, 2005, 01:39:22 PM »
im pretty sure its the bellhousing on the left thats whats on my truck anyways. :driving:
Building the CRUISER
b_ripper8
  • Turtle Points: 371
  • Male Posts: 275
  • Member since May '04
  • 3RZ-FE power is that much closer.
« Reply #3 on: Jun 07, 2005, 03:18:35 PM »
The one on the left.
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • yellow beast
« Reply #4 on: Jun 07, 2005, 05:02:14 PM »
2wd or 4wd shouldn't matter.  isn't the one on the left an R151F bellhousing and the one on the right a G/W series?
b_ripper8
  • Male Posts: 275
« Reply #5 on: Jun 07, 2005, 05:04:00 PM »
both my 4X4 g and w series look like the one on the left. Never seen a R151.
« Reply #6 on: Jun 07, 2005, 05:47:20 PM »
the right side bell is a 2wd or L43,  but they were originally a 2wd tranny so :dunno:
toybuilt
  • Turtle Points: -275
  • Male Posts: 1,116
  • toy + chevy = Toy-vie
« Reply #7 on: Jun 07, 2005, 08:49:10 PM »
I don't think that 2wd bell houseing are detachable, I do know that the one on the left is off a 4wd 4 cylinder.
2021 Toyota Tacoma TRD Off Road
1983 Toyota Turned Chevy
Treat every day like its your last, because you never know when your time is up. In loving memory of Judstin.
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #8 on: Jun 07, 2005, 09:30:21 PM »
Both of my 2wd bellhousings are detachable, and niether of them looked like the one on the right.  Mine were 83 and 89 celica and truck trans.
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #9 on: Jun 07, 2005, 10:04:24 PM »
ahh, that could be it.  L43s had a cast iron case and a removable aluminum bellhousing.  never took mine off though.
G, W, R and L trannies were all used in 2wd trucks as well.  most just had higher gearsets and a different tailshaft/housing.  as far as bolting up behind a 22R, they're all the same 2wd or 4wd.
  • Turtle Points: 2124
  • Male Posts: 18,289
  • Member since Apr '02
  • 511:1 Club
« Reply #10 on: Jun 07, 2005, 10:07:34 PM »
Yup, right is definately a W or G series, and, I'm not 100% sure, but if it's a Toy belhousing, then it'll be a 4 speed L43.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #11 on: Jun 07, 2005, 11:00:57 PM »
Both of these 2WD bells will fit 4WD transmissions. However, I would not advise using them, because they are both light, thin cast versions that were not designed for the added weight of the t/case.
Left side, 9 bolt small pattern;
  81-88 G40 4 speed
  84-95 W45, 46 4 speed
  81-95 G52, 53, 54, 57, 58,  5 speed
  84-95 W52, 52, 55, 56 5 speed
Right side, 7 bolt dual pattern
  69-80 L40, 42, 43 4 speed
  71-84 W40, 42 4 speed
  71-85 W50, 52 5 speed
« Last Edit: Jun 07, 2005, 11:22:11 PM by Marlin »
fourwd1 [OP]
  • Out On Bail
« Reply #12 on: Jun 08, 2005, 11:39:50 AM »
Thanks Marlin !
I knew at least one was from a 2WD. I was deciding wether to keep or trash (recycle).
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
« Reply #13 on: Jun 08, 2005, 08:21:59 PM »
2wd bells are detachable aaron, remember, i had one that we took apart like 10 times :usa:
« Reply #14 on: Jun 10, 2005, 03:54:20 PM »
  81-88 G40 4 speed
hey Marlin a guy i know has a 89 with the G40,  can it be made into a 5 speed like the L45????
« Reply #15 on: Jun 10, 2005, 03:57:16 PM »
not that he needs it with the G662 diff,  seems like that was like a 3.07:1
Marlin
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #16 on: Jun 12, 2005, 08:42:54 PM »
Yes 79Coyotefrg, the G40 can be upgraded to a 5 speed :thumbs:
« Reply #17 on: Jun 13, 2005, 06:11:29 PM »
cool,       i assume any G52/54  5th gear parts
Last post Nov 05, 2019, 07:06:50 PM
by wslytoy
Last post Dec 30, 2019, 08:16:57 AM
by Bob Williams
Last post May 05, 2020, 12:26:26 PM
by djui5
Last post Sep 16, 2020, 03:27:19 PM
by CrazyYota
Last post Oct 05, 2020, 09:48:39 PM
by Russ86
