Ok so i did what everybody said. I used a jumperr wire to set the timing and it made it idle much smoother and not nearly as noisy. But when I took it for a test drive it was completely gutless until about 3000rpm From what BigMike said about the valves needing to be adjusted I think this could be the problem.
This is an Automatic right?
No Mike this is a 5spd
The switch code says in the chiltons: Diagnosis: Displayed when IDL contat OFF or shift position in "R", "2", or"1" ranges with the check terminals E1 and TE1 connected
after messing w/ the tps for a while I asked him if the little allen head w/set screw adjuster on the throttle cable was important he said YES why? Well that was how I was adj my Idle . That was my problem couse my computer was trying to compensate the fuel flow couse I had that screw set way in and it was not allowing the computer to set the idle anyway after we adj that the tps came to life .
Started by dirtman Toyota Pickup/4Runner Tech 1979-95
Started by 85 yota Toyota Pickup/4Runner Tech 1979-95
Started by montanatoy Engine
Started by miks85yota Engine
Started by woodbedtoy Toyota Pickup/4Runner Tech 1979-95
