installed header now wont run its flooding out and loading up.
Started by montanatoy, October 09, 2006, 06:49:44 PM
montanatoy
I have a 1982 sr5 4x4 22r with webber carb just got done installing a header with 2 1/2 exhaust with flowmaster muffler it did have a cat with 02 sensor removed it ran good right after i did the install but now acts like getting way to much fuel and loading up real bad.  What have you guys done with the o2 sensor i just cut the wire to it What did i do wrong or should i do?  Any help would be appreciated I did pull header off same year truck it ran great but not mine.
Thanks
MONTANA TOY
toyotas are like tonka trucks of old built to beat the hell out of
if you got a weber  the wires to the o2  have absolutley nothing to do with the truck anymore
sounds like the float  is sticking,
montanatoy
float seems to be ok acts like to much fuel.  Should i put on a fuel reg ?  I installed a new fuel pump also
thanks
um  yea  if you just put on a new pump then it might be the pressure
4inchToyotas
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
montanatoy
Im going to try the regulator guess it wont hurt anything.  Any other suggestions?
Duffil
When you put the new pump on, did you reinstall the spacer that goes between the pump and the head? shown below.  If you leave it out, the fuel pressure goes way up.
montanatoy
Duffil thanks for the heads up that was what was wrong with it just need to get carb tuned right then should run good also put on regulator.  Thanks everyone for there knowlege that is what makes this sight the best on the web, good people alot of knowlege and very helpful!
montanatoy
