body lift pics ...???
Started by chevyLUVtoyota, May 14, 2005, 08:45:42 PM
chevyLUVtoyota
hi can sum one take a pic of your shifter boot with a 3" lift on ??? :beerchug:
thanks
thomas
86 4runner
i dont have pictures, but i had to unscrew it or else i couldnt shift into 4wheel drive. ill try to get  picture
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
Rockdiver
You will have problems with boot or floorboard hitting with 3"  you can heat shifter and bend to help some   I found Marlins short throw shifters can use stock boot & floor no mods
chevyLUVtoyota
ya ill shift it to 2ed and it will pop in to N it sucks i just want to clere 33s thats all ...
unclejpl4x4
well what are U looking for?   I got a 3" body    I can take U a pic for U  but what are U trying to see?
Rockdiver
Take your boot off and shift through the gears while sitting still   note how close the shifter comes to the body at each gear if it is only hitting body in second and there is some space between 1st and the body you can bend the shifter foward . You will need to heat the shifter near the base and bend forward . Try all gears again. Most muffler shops can heat and bend this for you .  If the shifter is not hitting the body it might just be the shifter boot puting it in a bind ,there you can get a aftermarket larger shift boot to solve the problem. Hope this helps you . I have a 3"body  on my 85  bent shifter stock boot . Marlin sells a short throw kit for the Trans  that will make the patern closer andwork with a body lift . I have 2 of his short throw shifter kits on my transfer cases and they are the only way to go I think for the transfer cases on trucks with 3" body lifts       Lynn
chevyLUVtoyota
i just need a pic of what haw short the shifters and boot is ....
unclejpl4x4
I can't tell if theres any extention in the stick  or if anyone even makes any :dunno:   but as U can see  13" from the floor of the hump.
feels good to me :beerchug:
the_experience03
     I had the same problem with the floorboard and shifter boot bind.  I ended up making my own shifter extensions to solve the problem.  I just went to the hardware store, shifters in hand, and grabbed two bolts with about the same shank diameter as the shifters and about a 4 inch unthreaded section although you could use whatever length you wanted.  Then, I just cut the heads and the threads off, cut the shifters, and welded the extensions into place.  Worked great and is plenty strong.  Now the boot is just slightly more stretched than stock, but is a bit closer at hand.
     What's really cool is that you could cut the shifter in a less than straight manner so that it will be bent a little to get the t-case shifter away from the gear shifter up top while not interfering on the bottom.  The only other thing to note is that you might still have to heat it up slightly to adjust it *perfectly.*
     Also, be aware that this will lengthen your shifter throw so any slop will be more noticable.  I didn't have any that was beyond toleration in mine, but if you have an older tranny, it might be worth noting.  Shifts will be even easier now though....I went from needing 2 fingers to engage the t-case to only needing 1  :biggthumpup:
chevyLUVtoyota
thats what i wanted to see thanks haw did you get your shifter like that away from the 4wd shifter? anyone have a pic of a 79-83 with 3" body lift??? my 4wd shifter is way short like the nob is on my floor bord
unclejpl4x4
well the truck had a 3" body  when i got it  so  :dunno:     but i don't have any rubing probles at all.   I look in the hole  but realy could not see anyting  i'll take a peek aging tomarrow     I am hoping my windos is in tomarro too :yupyup:
