Where to mount hi-lift jack
Started by gturismo, May 13, 2005, 11:42:22 AM
gturismo
I was wondering where you guys mounted your hi-lift jacks, especially if you have a 4runner.  Pics would be appreciated if you have one.  Thanks!
85 Runner
KYOTA
mounted mine on my spare tire mount. in a 4runner you could probably bolt it to the top of the wheel well on either side
If you have the original rollbar there will be a treaded hole. I used 2 old front upper shock bushings 1 on each side and bolted mine there. I is a perfect spot. Sorry no pics since I no longer own my 4Runner.
robinhood4x4
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
mudaddict
i jsut got the mount that they sell for it and then drilled some holes in my back (behind the rear seats) and put it there took out the back seats.
I work At
All Pro Off Road
No Power
I bought hi-lifts mounting system that locks :yesnod:
So I just mounted mine on the front bumper of my 4-runner.
Check hi-lift web site for mounting brackets :thumbs:
Good luck and let us know how it turns out for ya :beerchug:
Roll me back over !!!
Here is mine.  Locked to the tie down ring next to the tailgate with a key lock.  Just barely fits with my bed bobbed 10 inches.
Snowtoy
I used to mount mine on the front grill guard I had.  I made two 90 degree brackets, bolted one side to the grill guard, and mounted a  long bolt to the other side of the bracket and bolted the jack to it.
Old mount
I have since built my own custom bumper and built a cradle to hold the Hi-lift.
If you don't have a way to mount it externally, bolting it to the roll bar would be about the easiest way of securing it.
