The Capacity/Size/Weight/Length Thread
Started by BigMike, May 07, 2005, 10:52:43 AM
oh yeah, you know it. better make it a Cold Mtn. Dew :thumbs: :eyebrow:
crawlerdan
Cheesemaker
Can we get more info on the LC front axle widths? Mike has up to 85 and then starts back up at 90!  Is there any difference in axles between them?  This is the post to have all the details!
Destruct O
#63
Does any body have the dimensions for the 98-00 Tacoma's frame?
Destruct O
MiniSimp
Approximate length of W56/RF1A-Crawl Box/MC08-R10/RF1A
#65
Toyota logos:
Formula One Logo:
Honduras Logo:
Team Argentina Logo:
Newer Truck Logos:
MiniSimp
I thought this was important to have in here:
the top of the factory IFS front crossmember is the same as the top of the frame, where an 85's front cross member sites 1.46" higher than the frame
Reference: http://www.pirate4x4.com/forum/showthread.php?t=599542
Also for reference, my shackle bolt hole through the frame is the exact same height as my front spring hanger bolt hole.
MiniSimp
mauidogg
Quote from: MiniSimp on November 11, 2005, 10:15:53 AM
Diff Breathers:
The tap size for toyota diff breathers is 1/8" NPT, 27 Thread per inch.
I found that 1/8"BSP fits, I used a 1/8"BSP male to 1/4" NPT female fitting to run my diff breather hose.
Doof
Slolyfe
does anyone know the weight of an 82 longbed?
You'll never take me alive
i couldnt find how much gear oil i needed in my 87 front diff, rear diff, trans and transfer case.. .anyone?
toybuilt
2021 Toyota Tacoma TRD Off Road
1983 Toyota Turned Chevy
Treat every day like its your last, because you never know when your time is up. In loving memory of Judstin.
MiniSimp
854RUN
Ok so i was do some googleing on the g58 tranny (have one, wonted more info on it) and found this wealth of info and decided we needed it so here you go  :biggthumpup:
Taken from MoparChat
Posted for informational purposes only.
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed and the 87-92 Toyota Supra Turbo R154 5-speed all share the same case to bellhousing bolt pattern. As such there are a number of possibilities that can be had when a 5-speed is desired:
94-95 Dakota 2.5L bellhousing: Connects R154 to any K car based 2.2L-2.5L L4 in a RWD application.
94-99 Dakota 3.9L V6 Bellhousing: Connects R154 to any 3.9L V6 and any 273/318/340/360 V8.
96-99 Dakota 2.5L bellhousing: Connects R154 to any Jeep 2.5L L4. Because of it's GM inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8.
88-99 Jeep 4.0L L6 bellhousing: Connects R154 to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
01-03 Jeep Liberty 3.7L V6 bellhousing: Connects R154 to any 3.7L V6, 4.7L V8 and 5.7L Hemi V8.
R154 Ratio's 1st 3.30:1 2nd 1.95:1 3rd 1.34:1 4th 1.00:1 5th 0.75:1 Rev 3.20:1
The R154 is a particularly robust transmission. It shares it's design with the AX15 but is built to a different spec. Not in the Tremec class, but better than a T5. It would work well in certain applications. The deciding factor to use something like this would probably be cost. Good used R154's can be had for about $300 and bellhousing for about $50. Converting to a hydraulic clutch would add a bit more expense but still, nowhere near the price of a Tremec. So, if you've got a 318 2 barrel in your daily driver, this might be for you. It should be pointed out that Australians LOVE these gearboxes for V8 conversions.
So, this is what CAN be done with stock, boneyard parts. Enjoy.
Greg Williams
More information from TurboDodge
There's your Rear Wheel Drive kit.
87-92 Supra Turbo 5-speed and yoke
94-95 Dakota 2.5L bellhousing, throwout bearing, slave cylinder and fork
94-99 AX-15 Front bearing cover
You'll need a 21 spline clutch disk. Might be able to match up one from a Toyota V6 truck.
Greg
Taken from Jeep-Offroad:
Part I
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed, the Jeep NV1500, the Toyota R150F & R151F, the 87-92 Toyota Supra Turbo R154, the Isuzu AR5 and the Pontiac SolsticeSaturn SkyChevy Colorado GMC Canyon MA5 5-speeds all share the same case to bellhousing bolt pattern (Large Pattern). As such there are a number of possibilities that can be had when a 5-speed is desired:
Pic 1. Novak Enterprises: Adapter plate for AX15 to GM 4-speed bellhousing. Connects all except NV3550 and NV1500 to same.
1.
94-95 Dakota 2.5L bellhousing: Connects all to any K car based 2.2L-2.5L L4 in a RWD application.
2.
96-00 Dakota 2.5L bellhousing: Connects all to any Jeep 2.5L L4. Because of it's GM 60 degree V6 inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8. Also bolts to any Isuzu 3.23.5 DOHC V6, Holden (Australia) 3800 V6 and the LS4 5.3L V8 from the Impala SS.
3.
88-99 Jeep 4.0L L6 bellhousing: Connects all to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
4.
94-99 Dakota 3.9L V6 Bellhousing: Connects all to any 3.9L V6 and any 273/318/340/360 V8, Magnum 5.25.9 V8, 3.7L V6, 4.7L V8, 5.7L Hemi V8, and Jeep 2.8L CRD Turbo Diesel. (Requires use of an 11" flywheel.)
5.
96-04 Toyota Tacoma 3.4L V6. Also works with Toyota 3.0L V6
6.
86.5-92 Toyota Supra Turbo 7M-GTE. Also works with Toyota 5M-GE.
Not shown:
01-04 Jeep Liberty 3.7L V6 bellhousing: Connects all to any 3.7L V6, 4.7L V8 and any 273/318/340/360 V8, Magnum 5.25.9 V8, 5.7L Hemi V8, and Jeep 2.8L CRD Turbo Diesel. (Requires use of an 10.5" flywheel.)
03-04 Jeep LibertyTJ 2.4L bellhousing: Connects NV1500 to 2.4L SOHCDOHC NeonSRT-4PT Cruiser L4 (See info at 11)
Isuzu Trooper 3.5 V6 AR5 bellhousing: Connects all to any Isuzu 3.23.5 V6
04-05 Chevy Colorado GMC Canyon MA5 bellhousing: Connects all to any Vortec 2800 L4, 3500 L5 and 4200 L6
06 Pontiac Solstice Saturn Sky MA5 bellhousing: Connects all to any Ecotec 2.4L
88-95 Toyota Landcruiser: 1L, 2L and 2L-T Turbo Diesel truck bellhousing connects to R series transmissions. (See Pic 2 Note below)
Aftermarket:
Advance Adapters: Bellhousing for AX15 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6. Connects all except NV3550, NV1500 and Pre 1996 R150 and R151 to same. http://www.advanceadapters.com
Advance Adapters: Bellhousing for Pre 1996 R150 and R151 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6. http://www.advanceadapters.com
Advance Adapters: Bellhousing for NV3550 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6.
Advance Adapters: Adapter plate for AX15 to Ford bellhousing. Connects all except NV3550 and NV1500 to same.
Advance Adapters: Adapter plate for NV3550 to Ford bellhousing.
Marlin Crawlers: Bellhousing to connect all to 2RZ / 3RZ Toyota 4 cylinder engines http://www.marlincrawler.com/
Japanese Auto Repair: Bellhousing to bolt all transmissions to a Mitsubishi DOHC 4G63. http://www.japaneseauto.com
Swift Machine: Adapter plate for NV3550 to GM 4-speed bellhousing. http://www.swiftmachine.com
Suzuki Only Supply: Adapter plate to bolt R series to Suzuki 1.31.6. http://www.rock4xfabrication.com/ringr.htm
Thor Racing in the UK: Adapter plate to bolt an R154 to a Toyota (Lexus) V8 automatic bellhousing. http://www.thor-racing.co.uk/R154_to...FE_Adaptor.asp
Part II
Jeep AX5, Toyota G52, G58, W55, W56, W57 and W58 5-speeds all share a common face pattern on the case (Small pattern). As such, any 88-99 Jeep 2.5L bellhousing (NOT Dakota) will bolt a Toyota W series transmission to a 60 degree GM bolt pattern.
Factory: 1981-86 1L, 2L and 2L-T Turbo Diesel truck bellhousing connects to W and G series transmissions. (See Pic 2 Note below)
1982-92 Lotus Excel - W series bellhousing to bolt Toyota transmission to Lotus 2.2L DOHC 4.
Aftermarket:
Advance Adapters: Bellhousing to bolt a W and G series Toyota trans to a Chevy-Buick-Olds-Pontiac block.
Northwest Off Road: Bellhousing to bolt W and G series to Ford 5.0. http://www.northwestoffroad.com
Suzuki Only Supply: Adapter plate to bolt W and G series to Suzuki 1.31.6. http://www.rock4xfabrication.com/ringr.htm
Acme Adapters: Adapter plate and flywheel to bolt VW 1.6, 1.9 Diesel to W and G series transmisson. http://www.acmeadapters.com
Japanese Auto Repair: Bellhousing to bolt Toyota W and G series transmissions to a Mitsubishi DOHC 4G63 bellhousing. http://www.japaneseauto.com
Red's Headers: Bellhousing to bolt Toyota W and G series transmissions to a 32-48 Ford Flathead V8 http://www.flatattackracing.com
OTT Industries: Adapter plate to bolt an SM420 5-speed to any Toyota W and G series bellhousing. Can also be used for a GM pattern T5 and Tremec TKO. http://www.ottindustries.com/
Advance Adapters: Adapter plate to bolt a large pattern AX15 to a small pattern AX5 bellhousing. Can be used with the other Long Shaft transmissions except the NV1500 and NV3550.
Part III
NOTE: Input shafts lengths vary.
Pre 1995 R150R151 = 6.5" 1996 up Toyota R series = 7.5" AX15 = 7.875" 87-92 Turbo Supra R154 = 7.25" AR5 = 8.2" MA5 = 8.2" NV3550 = 7.875" NV1500 = 8.6" AX5 = 7.5" Toyota W series = 6.5" Toyota G series = 6.5"
Pic 2 Advance Adapters makes an extra long pilot bearing when using a slightly shorter input shaft tranny with a bellhousing that had a longer one. Obviously you can't put the longer input shaft trans into a Toyota bell that had a shorter one. (Unless a spacer is used or the input shaft is swapped. See below.)
The transmissons and bellhousings can be split up into two categories. SHORT SHAFTSHORT BELL and LONG SHAFTLONG BELL. They cannot be easily mixed without modifications.
All AX15's, AR5's, MA5's, NV3550's, R154's and Toyota R150's (built after 1996) are LONG SHAFTLONG BELL. To use one of these in a SHORT SHAFTSHORT BELL application requires a 1" spacer available from Japanese Auto in Toledo, OH ( http://www.japaneseauto.com/ ), Dellow Automotive or Castlemaine Rod Shop in Australia. Of course, any bellhousing combo one can think of is also available from them...
http://www.dellowauto.com.au/catalog...Automotive.pdf
http://www.rodshop.com.au/
ALL Toyota R150's and R151's built before 1996 are SHORT SHAFTSHORT BELL. These CANNOT be used in a LONG SHAFTLONG BELL application or with LONG SHAFTLONG BELL adapter plates.
Pic 3: Example of a LONG SHAFT transmission hooked up to a SHORT BELL with a Dellow Automotive spacer
The Jeep AX5's 7.5" input shaft does not allow it to be used with the Toyota G and W series bellhousings unless a spacer is fabricated OR the input shaft is swapped between them. (Apparently the short 6.5" G series Toyota input shaft can be made to work in an AX5 case and vice versa). The one exception is shown below.
The Jeep NV1500 has the longest input shaft of the group at 8.6".
Pic 4: All of the large pattern transmissions. Pic 5: All of the small pattern transmissions.
Trans First Second Third Fourth Fifth
AX15 - 3.83 2.33 1.44 1.00 0.79 AR5 - 3.753 2.26 1.37 1.00 0.729 MA5 - 3.753 2.26 1.37 1.00 0.729 (Colorado/Canyon/Hummer H3) MA5 - 3.75 2.26 1.51 1.00 0.729 (Solstice/Sky) R150 - 3.83 2.062 1.436 1.00 0.838 R151 - 4.31 3.32 1.52 1.00 0.83 R154 - 3.25 1.95 1.30 1.00 0.75 NV1500- 3.85 2.25 1.48 1.00 0.80 NV3550 - 4.01 2.32 1.40 1.00 0.78 Aftermarket gearset by OS Giken for Toyota R, GM/Isuzu AR5 and Jeep AX15: 2.701 1.614 1.215
-JOSH-
Winch
I've seen the thread above regarding T-case lenghts, but does anyone perhaps have some info on the gear driven T-case heights?  I've got only 1/2" between my 1980 T-cases and the floor, and was wondering if the newer style topshift cases have the same dimentions.  Thanks
'02 Tacoma Double cab, 5 speed swap, dual T-cases, dual E-lockers, FJ80 SAS, 37" MTR's
'80 Toycoma, 5 speed swap, 3.4 L, IFS, Air, Airbag, Power locks
Lotsa Toyota parts for sale:
http://winchstoyotaparts.yolasite.com/
twistedtoy92
solar86yota
Some dry weights for 1st, 2nd and third gen trucks would be nice!
By the time I get the money for an SAS I'll be 65 at this rate!
ElkoToy
Great topic saves a guy a lot of time looking this stuff up every time.
MiniSimp
Anybody have an overall cab width at the rear for a 2nd gen?
Duffil
Quote from: MiniSimp on January 13, 2009, 01:58:07 PM
you too lazy to walk outside?
sixty-three point five inches.
MiniSimp
Quote from: Duffil on January 13, 2009, 11:10:15 PM
I have a custom narrowed cab (narrowed by squeeze rock) my cab measures 60" wide. :talkingn:
Cheesemaker
Mine is 64.25" at the widest spot on the back of cab.  That is not including the molding.
And the third gen is 1.5" wider than the 2nd gen.  Don't ask me know I know!!  :yupyup:
MiniSimp
Quote from: cheesemaker on January 14, 2009, 09:54:45 AMAnd the third gen is 1.5" wider than the 2nd gen.  Don't ask me know I know!!  :yupyup:
Now I've gotta ask....how? :greengrin:
Cheesemaker
MiniSimp
Doof
size/length/pitch of the nuts from header to downpipe (stoke 22re)... anybody know it?
Duffil
cavey
here's another for the VIN numbers   hilux dual cab diesel 4wd LN 106 1988-1997
own a 1989  LN106r diesel with a 1KZ-T 3 litre turbo diesel  bolted to a imported R151F gearbox with snorkel Rancho springs & shocks & Detroit lockers F & R & 11x 32  cooper sst ultimate dual transfer cases 130 litre fuel tank   full floating disc brake rear end
