How to Pass Smog
Started by BigMike, February 24, 2003, 03:29:47 AM
Goose
Quote from: Plekto on January 04, 2008, 02:39:19 PM
This is why I just go out and get the $30 Bosch one at my local mom and pop auto parts store.   :yesnod:
Ive heard the universal bosch's are a big no-no...
I guess they dont read right for toyotas like the oem ones do or somthing...
idk, ill have to look it up. Theyre way cheaper but i heard theyre bad...
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
I'm using a Bosch with no problems
I did however upgrade it to a heated 3-wire...........
drabnor
Hey guys, I could use a bit of help with my '86 22rte 4runner, my first 22r series yota. It failed a pretest yesterday. First thing that surprised me was the timing, with the terminals shorted its at 15 * BTDC, unshorted its about 22* advanced :yikes: So I figure thats my first thing to do is to time it correct. Heres the #s it got:
test ------ rpm --- HC max --- HC measured --- CO max --- CO measured --- NO max --- NO measured
15mph --- 1761 --- 131 ---------- 67 ---------- .87 ---------- 0.00 -------- 1085 ------ 1868(fail)
25mph --- 1727 --- 103 ---------- 52 --- ------1.10 ---------- 0.00 -------- 1120 ------ 1933(fail)
notice the complete lack of CO and the high NO... would the timing so far out of whack cause the high NO?
its got new plugs/wires, i seafoamed it about 500 miles ago, running 87 octane.
it also failed CA's new evap system test so i plan to replace all the hoses in the system.
tia for the help!
86 4runner
00 Tacoma
Goose
Quote from: drabnor on February 06, 2008, 11:41:15 AM
details on that  :bull crap: ??
Hows the sea foam work for you?
I usually dump some propynal alcohol (Spelling?) in a fresh tank every few months... cleans the valves and what not nicely..
How old is the cat?
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
drabnor
Quote from: Goose on February 06, 2008, 02:06:40 PM
details on that  :bull:pokinit:: ??
How old is the cat?
its a new test they just started doing on the 1st of Jan, pressure tests the entire evap system, if it doesn't hold x pressure for x time you fail
seafoam worked great, suck it into the throttle body and it cleans the intake tract/combustion chamber of carbon, also put it in the gas to clean the injectors
unsure of the cat's age, its prob original as well as the o2 sensor...
i plan on changing the o2 just to be sure. something is making it run lean, very lean ~15.7 a/f ratio
86 4runner
00 Tacoma
NOx goes up with advanced timing.    Back off the timing to 2-3 degrees BTDC (spec is 5 BTDC  and you're allowed +- 3)
Goose
Id definetly replace the cat.
Sometimes a brand new Nice n hot cat can burn off.. or hold back, alot of nasty stuff.
The o2 sensors are spendy, but well worth it.
Espesially if its running lean like that..
14.7's perfect right?
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
drabnor
Quote from: emsvitil on February 06, 2008, 05:36:50 PM
Thank you! I'll give it a shot and see what happens...
86 4runner
00 Tacoma
Plekto
Quote from: Goose on February 05, 2008, 10:05:11 PM
I think for a 22RE, they are fine if you get the right one.  It was the only one listed in the computer and the item looks identical to the OEM as well.
Other types that plug in near the cat are a whole other story, you're right.  All I know is I passed smog, if barely.  NOx is O2 sensor most likely of if you're running stock exhaust, look for leaks and cracks near the sensor.(also cat, but O2 is usually much cheaper and you're not far off.
superyota
any idea if the smog year will ever change again?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Plekto
Whenever Feinstein and Boxer leave office.  They hate diesels and old cars with a passion.
P.S. The real reason they sued the EPA for stricter limits was because they want to keep the Mercedes bluetec and other similar lean burning diesels out of California.  It doesn't matter to them if you could suck off of the pipe and get cleaner air than by opening the window - they are on a mission to get rid of every last one.
Thankfully the EPA kicked them in the shins.
Quote from: superyota on February 20, 2008, 09:39:41 AM
Doubtfull, they're already up to years that started to have a decent amount of smog control crap.
Orowheeler
my 22re is completely rebuilt and i didn't pass smog because of my o2 sensor i from a pick and pull. so it is worth spending 100 bucks for a brand new one.
davidr34
to get the hc down, retard the timing correct? And can anyone send me some pics of where the 2 hoses go from the a/c line? ive look at the diagram i just can figure it out. thanks
fordh8r
Quote from: davidr34 on March 10, 2008, 01:32:56 PM
:yesnod:  BUT! You can't be more than +/- 2 degrees from the spec.
You retard for high NOx.
HC & CO are the opposite, so I think you advance a little
Misfit4Runner
well i tried to get my runner 3.4 smogged and blew over 200 points on my NO at 15mph. so i sprayed a half can of STP choke and carb cleaner (sensor safe) in the carb and a pint of rubbing alchol in the tank and knock off my air cleaner. 20 min later I passed 293 out 512 at 15mph and 222 out of 765 at 25. im not sure if guy at the 1st place was a complete yahoo or the carb cleaning and alchol was what did it. I was gonna change the oil but after 120 on smog tests I said to hell with it.
If you dont stand behind our troops, Please feel free to stand in front of them.
88 xtra cab sas'd dual cases flatbed
superyota
ABD Motorsports
#4475
KK6QDW
Duffil
Quote from: superyota on April 18, 2008, 09:58:04 AM
3.4 with a carb?
i think he means he sprayed carb cleaner in the throttle body
85toyrunner_rockrig
i love living in SW colorado, no smog req.
johnstrings
Thanks...
That is VERY informative...
:thumbs:
Johnstrings
potter85
smog is just another way to drain money from people....It has a great idea behind it but unlike what everone assumes not all smog comes from cars. I dont see grandpa smogging his tractor every 2 years... Same with laws like the beadlock law... They enforce it for the money
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
86rustbucket
yes smog is bull crap.go smog your black n white piggy
86rustbucket
iv had good luck by filling up with chavron 91 and a bottle of berrymans fuel system cleaner.run out most of the tank and go to the smog shop with the engine goog and warm and let the engine idle while your waiting
usmc4runner
Im in atlanta and i failed horribly the first time.. popped a vacuum leak and passeed she did
superyota
just took my 90 4runner with 3.0 in for smag today and it failed horribly.  i put new ngk plugs in it yesterday, new cap/rotor/wires, 91 octane chevron, and 1 bottle of rubbing alcohol, cleaned the air filter(k&n), turned the idle up to 1000 rpm, and also retarded the timing 2 deg. Also used a infrared gun today to check the temp before and after the cat and it was almost 100 deg. hotter after the cat, so i'm assuming its working right.  here are the numbers:
                            %CO2    %O2    ( HC----------PPM)  (-----------CO%-----------)
Test          RPM       MEAS    MEAS    MAX    GP    MEAS    MAX    GP    MEAS    Results
Idle           991        11.32    0.5       120    270    2376    1.00    2.50   4.92     GROSS POL
2500 RPM   2683       12.26    0.2       180    330    324     1.00    2.50   3.97     GROSS POL
GP=Gross Polluter Limits
MAX=Max Allowable
MEAS=Amount Measured
any suggestions?  just went to dmv and got a 30 day pass for it.
ABD Motorsports
#4475
KK6QDW
Pat
#176
it is running extremely rich..  Check you efi system..  It is so rich it is causing the Hc to be extremely high..  Does this truck seem like it even runs good?  High hydrocarbons mean you are in a misfire condition when it is that high..
Most EFI toyotas when running correct are close to .00 to .03 on the co% even if you took the cat off :hammerhead:
Sharing time between Northern Ca and Western Tn..
superyota
runs a little rough at idle.  but off idle it runs great.  i still havn't figured out why it runs ruff.  do you think a new cat would even come close to cleaning it up?
ABD Motorsports
#4475
KK6QDW
Pat
no, not running that rich..  You either have a real issue with way too much fuel or a cylinder that needs attention..  Do a compression test before you go to crazy in the troubleshooting ares..  Does it use water at all?
how many miles are on this motor?
superyota
no, the old motor had bad gaskets, just replaced it with one i got off priate from a guy in placerville, supposed to have 110k on it. it was in his 4runner and it was his daily driver.  ran great.  he pulled it out after i paid for it.  doesn't use any water, or oil.  i'm wondering if the old motor with bad gaskets and buring oil could ruin the cat, but if it won't lower the emissions, i don't see the point of changing the cat.  i'll try a comp. test.  thanks for the info.  i'll keep posted.
ABD Motorsports
#4475
KK6QDW
