Thanks for the reply yotaboy. About how much lift did you get out of that combo? Any pics? How's the pinon angle and stuff like that?
i got about 4 maybey 5 in of lift the lift mostly depends on how you make the spring pack i used the toyota 2wd main leaf then cut down the main leafs from a waggy set then the others are the bottom 5 leafs from the waggys then i added the stock toyota front bottom leaf to the drivers side pack where it fit to compensate for the different spring perch highths the pinon angle is fine the caster (wich is basicly the same measurement) was only .2 or .3 degrees off wich isnt even enouph to make any difference. and if you wanna see some pics look at my build up thread its "this may take a wile build up (79 toy)" i think it might be down to the second page if you want more pics reply here and i will take some more.
oh and if you plan on puting longer springs in the rear and you dont wanna re use your stock shackle hanger and wanna save some
you can make your own im using 2x2 .120 wall square tube notched to fit 1 1/2 tubing for the tubing you can use 1 1/2 .188 wall D.O.M. its the perfect inside diameter to fit the stock toy bushings.
is this too much info for ya lol
good luck and happy building
