Besides foaming, too much oil robs HP as the reciprocating mass muss whip through it (crankshaft). It'll create excessive oil consumption by blowing oil out your breather/PCV. Can cause fouled plugs, and at the worst oil leaks.
1/2 quart over full mark is as far as i would go
blackdiamond, after using seafoam you are supposed to change the oil
rocktoy, you need a overhaul BAD, where are you ?? maybe i can help you outblackdiamond, after using seafoam you are supposed to change the oil
I know that running too little oil is very bad for a motor, and also that too much isn't good either. How much is too much? I have never seen it quatified. my oil pan is dented (slightly smaller volume) so I usually over fill a bit, but how much it too much?
Started by TEXXX General 4WD Discussion
Started by Bazzi Project Research and Build-Ups
Started by sof'indetermined Toyota Pickup/4Runner Tech 1979-95
Started by robrub00 Toyota Pickup/4Runner Tech 1979-95
Started by jasonnorcal Newbie Questions
