Truck being towed
Started by Ritchie, September 17, 2025, 03:53:03 AM
Ritchie
Hey guys... just a question about my truck being towed.
Is it OK to put the transfer case in neutral, and tow from California to Florida? Or, do I actually need to trailer it?
Thanks in advance.
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
RUGER
#1
ive flat towed my rig a few times not across country though, IF FLAT TOWING REMOVE THE DRIVE SHAFTS.
edit. for that distance i'd trailer it. could rent uhaul car hauler and put a set of smaller roller tires on so that the tie down straps can go around them. tell them yer towing a small car like a camry. years back they said my 1997 f250 diesel wouldn't rate towing my 83 toyota pickup.
RUGER
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
a1gemmel
Toyota t-cases aren't rear oiled like a jeep, they need the input to be spinning to be lubricated. Like Ruger said, I'd trailer it. If you've got some big ole mud terrains, the amount of tire wear you'll save will pay for the u-haul.
1981 Pickup - 35s, 5.29s, W56, dual ultimate, e-locker front, grizzly rear, 22R stroker, 3 linked on airbags
I flat tow when the need to do so and if a short distance (under 50 miles) I leave the rear driveshaft on but for long distance I always remove the rear. That being said if you don't have manual front hubs you'd need to pull both. I only take the axle bolts out and tie the ds up.
