Author Topic: New member hello and question about output shafts  (Read 1401 times)
gte
  • Member since Nov '23
« on: Nov 28, 2023, 01:41:31 PM »
Hello,
For a project, I need an output shaft that will fit a driveshaft disconnect device
    https://trailtough.com/product/rear-drive-disconnect-for-toyotas/
which I believe is a 21 splined output shaft from the following vehicles
  • 1979 – 1995 Toyota pick up
  • 1985 – 1995 Toyota 4Runner
  • 1995 – later Toyota Tacoma gear driven non-turbo cases only
is that correct? Does anyone have a picture of one?
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Hello,
If you google RF1A output shaft you'll see what it loos like
gte [OP]
Thanks, do you have any ideas on obtaining one?
  • Male Posts: 3,522
Unfortunately I handed 2 out this last few months. Do you have single case or duals that you are adding the dis connect? If you already have gear drive in your truck. The disconnect is a bolt on mod. I would start looking for somebody that has done a dual case setup. They should have 1.
gte [OP]
Ok thanks. Once I get enough posts I will post a Wanted to Buy in hopes that someone doing the mod you are referring to will have an extra one.
I'm adding this to a non toyota vehicle, so I don't have anything to start from.
  • Male Posts: 3,522
Just out of curiosity, what are you planning to put in.. are you planning on cutting down the toyota output shaft.
gte [OP]
Yes that's correct. I need the front portion to adapt to a factory slip yoke, then the DSD and then off to the front differential. It's a Nissan.
Trail tough told me the rear pinion spline is the same but it's very tight to slide onto and therefore could damage the bearing during install.
  • Male Posts: 3,522
What about a front output shaft. I have alot of those. Same spline I'm sure.. let me go get one out. I'll take a pic
  • Male Posts: 3,522
I pressed the bearing off to give you a better look. Also one pic with flange on.
Sent from my SM-G998U using Tapatalk
gte [OP]
Thank you for these. Fortunately Marlin just called me and told me they had a used one to sell for 45 dollars, so I bought it and it'll be here sometime next week with my DSD.
  • Male Posts: 3,522
That's great. I usually get 100 bucks for rear output. What a deal...
  • Male Posts: 3,522
Keep us posted. I'd like to see the final outcome. Sounds like a fun project.
gte [OP]
Will do. It'll either be an epic fail or cool project :)
  • Male Posts: 3,522
 :beerchug: get er dun...
a1gemmel
  • Turtle Points: 149
  • Member since Jun '21
  • Amateur shitbox whisperer
This project deserves a build thread
1981 Pickup - 37s, 5.29s, L52, dual cases 4.7 rear, e-locker front, grizzly rear, 22R stroker
1986 4Runner - 35s, 5.29s, auto, front Detroit, rear trutrac, 4" lift
gte [OP]
That might be a possibility, let me get the parts in and ensure I haven't engineered (in my head) a paper weight and then I can go from there
Slabzilla
  • Turtle Points: 1355
  • Male Posts: 539
  • Member since Dec '13
 :welcome:  Let's see where this goes.   :driving:
Last post May 22, 2004, 06:40:38 PM
by Aaronn
Last post Jan 15, 2005, 04:29:28 PM
by Willy Mammoth
Last post Aug 10, 2005, 10:57:36 AM
by Toy1
Last post Oct 27, 2013, 04:21:14 PM
by Luthierman
Last post Mar 17, 2015, 07:11:17 PM
by 808newbie
