Catalytic convertors
Started by Bigbadtoy, April 17, 2005, 07:12:20 PM
Bigbadtoy
how much should a new Catalytic convertor cost me for my 91 22re. i dont have one and im looking to buy one where can i get the best deal at??
i love playin in the mud
unclejpl4x4
chevyLUVtoyota
the best thing we do it gut thim out here cut thim off and take a big rod and smash the insides out and thin it looks like you have one
Skinny_Pedal
ebay. magnaflow hiflow cats. $60 to your door
Im an OG
BLACKDOG
              -Ronald Reagan
Bigbadtoy
im gonna just get a regular oem cat. because ever since i took it off ive been sucking alot of gas and it blows smoke out the exhaust when i take off and it smells like raw fuel i think my o2 sensor might be shot too but my check engine light isnt one anyone know what might be wrong?
whiteman
i have the same deal,  My truck runs realy rich and gets ya high when your driving.  I dont have a cat either just 2 1/4 with 40series flowmaster.  I have been told by some that my EGR valve needs to be replaced? :dunno:  What ever that is.
whiteman
Sorry forgat to say if ya can get a Highflow cat any were around or below  $100 it a reasonable price,  shop around first,  Also you can try some local muffler shops, Go for small shops, Not shops like midas, or other big names.  Somtimes they will have cats or mufflers that are used somtimes almost new and they might give them to ya.  Thats how I got my flow master, Some guy had it put on his s-10 and he thought it was to loud so he bought a different muffler and they had the flowmaster lying around and just gave itto me. :rockingout:
Bigbadtoy
thats cool. but ive been trying so much :pokinit: lately to see why its running rich and the only thing i can figure is its my o2 sensor. because it started doing it shortly after i took my cat out.
whiteman
I dont know for sure, but in theroy your O2 sensor is designed to work woth the restrictive flow ove a cat, therefore if you had no cat it would not make a difference :dunno:   Just a thought, mabey it will work. :confused:
unclejpl4x4
Quote from: whiteman on April 18, 2005, 04:33:10 PM
I don't know for sure, but in theory your O2 sensor is designed to work Worth the restrictive flow over a cat, therefore if you had no cat it would not make a difference :dunno: Just a thought, maybe it will work. :confused:
ya  the  cat  gets hot<pipe gets hot<  O2 gets hot :)   with no cat  the o2 is not at right temp.
@bigbadtoy
I would avoid gutting your cat  for smog/inspetion reasons
Uncle Jesse
the o2 sensor that has the most control over fuel strategy is in front of the cat, and most are heated.  Look at the sensor itself, it will be either a one or four wire sensor. The four wire being the heated one.  EGR systems are designed to work with backpressure, hence the back pressure transducer that feeds vacuum to the egr.
If you have a later model EFI truck with the "diagnostic" box, you know the one you jump to check codes, you can probe the box to read o2 sensor voltage.  Just use a Digital voltmeter, probe from the o2 pin to ground(e1 pin I think).  Lean is low voltage, say .1 to .2 volts, and rich is .7 to .8 volts.  A properly working sensor will toggle back and forth from rich to lean.  Just make sure the truck is at operating temperature.
