Does it still lock up on jacks?Sounds like the locker is jacking you up
... You are correct tires do change speed when going around a curve (I.e. the inside tire slows and the outside speeds up) and with a locker these tires are "locked" at the same speed. .
I still have lockouts so the front is never truly locked in unless the hubs are. Truck drives great in 2wd down the road with the hubs unlocked. No turning issues at all. The issue arises when the truck stopped and the hubs are locked in. Once this is done it immediately will not turn left past straight. Without moving an inch. But it will turn right.
A true locker does unlock when going around a turn, a welded locker or spool can't do this. Most people don't weld or install a spool in the front for this reason.
Mudmaster: 2wd hubs NOT locked in = no problem steering. 2wd/4wd hubs locked = immediately will not turn left
If your hubs are locked the front tires are still being forced to turn at the same speed because there isn't any give in the differential. The only different 2wd vs. 4wd is in 2wd the front axle is being pushed (i.e. coasting) and in 4wd it is being driven by the front driveshaft. The bind in the axles between the tires is the same either way.
The other thread linked a little while ago lots of people suggested a cracked or broken birfield joint
Started by sweetmeat Toyota Pickup/4Runner Tech 1979-95
Started by jrock General 4WD Discussion
Started by rmoore Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Mario Axle/Differential/Steering
Started by Yotaoverland Toyota Pickup/4Runner Tech 1979-95
