Datsun Divorced T-Case
Started by 1Bad4Runner, April 11, 2005, 09:26:40 AM
1Bad4Runner
I have just found a Datsun divorced T-case, it is gear driven with 2.07 low range gears. I was wondering if it is possible to run this behind a stock Toy T-case?
FATB0Y
I don't know about a toy case but I have joined two of them together. They are some tough SOB'z
Willy Mammoth
I had one behind my 4.3 turning 38" as a daily driver and towed some heavy :pokinit:. I did rip the side out of one once, but that was because the mounts were loose. I don't see the need to use one behind a Toyoa case, That sounds like mor work than it's worth. Also the drive line will be hard to get to run smooth with all the drive shafts needed.
86yota
Yea, I think it would be allot less expensive to use two toy cases.  Datsun's have the front output shaft on the drivers side also.  What this case is good for would be a setup like 4.3 litre/2wd SM420/Datsun case/ford high pinion 60s
1Bad4Runner
Hmm... That sucks. Well, at least it was free, I found it in the woods on a truck that has been sitting in the ditch for about 5 years now.
I guess I'll have to find something to put it in, Maybe my girlfriends dad's Ford Ranger  :gap:
If the cdase is divorced its a passenger drop if I recall correctly.  I believe they swapped over to driver side drop in 86 1/2. (?)
Willy Mammoth
Quote from: WHITE_TRASH on April 12, 2005, 04:19:58 AM
Yup Yup
You can rotate the case for whatever you need too.
1Bad4Runner
You can only rotate it 3 ways, if you turn it on one of the sides then the  shift linkage will be facing down.
I had it jacked up under my truck to see if it would fit and it looked good other than the stock t-case was in the way  :headscratch:
Oh well, I really need some diagrams on how to make the dual t-case adapter plate :dunno:
Has anyone ever made one before?
Thanks for the info on the t-case guys  :beerchug:
Willy Mammoth
Dual Toy adapter? Unless you got a mill and know how to use it I would just buy that from Marlin and spend your time doing somthing else like wheeling.
FATB0Y
Quote from: Willy Mammoth on April 13, 2005, 04:26:24 AM
what he said
IronClad
if i remember right  the front output is actually centerd. i had looked into doing   this myself.  ive seen some people  cut the front output off the married case ( the one behind the tranny)  and then  hook the divorced case up.  OR  you could clock  your tcase tranny and engine to the point of where its out of the way..  which is what i'll be doing to stuff an divorced np205 into my truck.   tripple  stick rear case   woooo  :gap:
Annihilation  Fabrication
Do you need a Hammer?
kyle_22r
i've heard of datsun cases used as a doubler in the days before marlin's crawl box adapter.  the 720 trucks had a divorced t-case with a wierd center drop(front and rear outputs are centered).  i think the front end is actually passenger drop, but has unequal length half shafts.  kind of a wierd beast if you ask me
1Bad4Runner
I like to build crap, if someone gave me plans of something I would build it... I guess if I looked at the T-case long enough I'd figure it out.
Quote from: IronClad on April 13, 2005, 11:55:59 AM
You are correct, the front and rear are centered, but you can turn it sideways... They are strange looking. I seen someone cut the front output off also, but its not a good idea.
Also I wouldn't clock my whole motor, tranny and t-case that far.
Quote from: kyle_22r on April 13, 2005, 04:30:51 PM
The truck I got it out of (busted up one in the woods) was independant in the front, so it was centered for a reason.
Now I have 2 divorced t-cases that I can't do anything with  :smack:
IronClad
you could  stack them up  so you had a front driveshaft long enough to  run it centerd and have a giant compound angle to the diff  :gap:
Duffil
Willy Mammoth
Even I being a Nissan follower at one time would not use that case anymore. Not saying it ain't a good case, but use Toy stuff, it just works together better than having a bunch of driveshafts to worry about. Put those on eBay and get rid of them. :thumbs:
1Bad4Runner
Maybe I will do that Willy Mammoth, since it was free.
