The timing is (as far as I know) set correctly, and I'm using mid-grade (87??) octane gas.
What happens with premium gas?
It sounds like you may have multiple issues going on. At 210,000 miles and the apparent lack of good maintenance by the previous owners, it can be very difficult to accurately diagnose the problem(s) you may be dealing over the internet.
a “pinging” sound in 22R can be several things other than pre-ignition caused by out of adjustment ignition timing.. Like heavily carboned combustion chamber, timing chain slapping against the timing cover, the fuel pump going out, exhaust leak, stuck valve, or valve lash out of adjustment.
Are you sure that the pinging your are hearing is pre-ignition? Unless you have lots of experience a “pinging” sound in 22R can be several things other than pre-ignition caused by out of adjustment ignition timing.. Like heavily carboned combustion chamber, timing chain slapping against the timing cover, the fuel pump going out, exhaust leak, stuck valve, or valve lash out of adjustment.
Pre-ignition or detonation can do severe damage to these engines in a short time.
What kind of vehicle is this - 4x4 pickup? What year? Automatic or stick shift? How long have you owned it? What have worked on or done to the engine? How many miles on the spark plugs, plug wires, cap and rotor? What octane gas are you running? Have you removed the rocker cover and checked the timing chain guides, or checked the valve lash? Have you pulled the spark plugs to see what the look like? Have you checked all vacuum hoses and verified they are properly connected to the right port?
Hi Lewis,Just from your posts, I would get that vehicle checked out by a good Toyota mechanic.It sounds like you may have multiple issues going on. At 210,000 miles and the apparent lack of good maintenance by the previous owners, it can be very difficult to accurately diagnose the problem(s) you may be dealing over the internet.
First make sure you get a timing light on there and mess around with your initial timing advance. If you need to retard it a bit but it won't idle you can open up the primary a bit (idle speed screw), like one extra turn or so and it should idle better.
I can see that you are regretting buying this truck but you have to expect these kinds of things from a 30+ year old vehicle. An 85 Toyota 4x4 is arguably one of the best trucks Toyota sold here.
Ok, you said plugs and wires were installed by previous owner, the guy that didn't change the oil, put screws in lightbulb sockets and used a zerk for a brake bleeder, I doubt he used the right plugs.
I would start there, get H8PVMNTs recommended plugs or get the Toyota recommended plugs and wires (OEM) with correct gapage. As I recall there was a Toyota carb guru you could send your carb to for rebuild if he is still around.good luck, keep the truck, and keep us posted
... An 85 Toyota 4x4 is arguably one of the best trucks Toyota sold here. They are hard to find in any condition....
These things are money pits no doubt...
Well... they can be, but early Toyotas are basically easy and inexpensive to maintain. A well maintained factory stock 1985 22R 4x4 Toyota Standard Cab pickup is arguably the most capable, reliable, and has the lowest cost of ownership per miles driven than anything in its class.
Maybe... I've probably put $400-500 into this thing over several repairs (minor and less minor), and the fixing, tweaking, and tuning is maybe half done. How does this compare to other vehicles in this class? I've only ever been around Toyotas, so I have nothing to compare against.Lewis
Bingo! .. Fixing this and replacing a missing bolt on the exhaust manifold cover seems to have fixed the problem. As a bonus, it's now quieter than I ever thought it could be.
Hey Lewis... glad to read your ping was not serious and easily fixed. Did you use a generous amount of anti-seize compound on the threads of the studs? Gnarls.... how stinkless can I go?
This is a damn good start and a more normal reply.
Started by 46&2 Toyota Pickup/4Runner Tech 1979-95
