Grey is the new red truck- low sas
Started by rybike, November 15, 2016, 07:39:26 PM
rybike
Quote from: THK Matt on January 12, 2018, 10:15:05 AM
:popcorn: dig it
Cheers  :beerchug:
Just noticed on your corolla sale thread it says sandpoint ID, Any good wheeling around there? your only about 3 hours from me
Quote from: rybike on January 15, 2018, 04:50:42 PM
Cheers  :beerchug:
i know there is a few newer offroad parks around. to be honest i havent ventured out to much other than logging roads and forest service roads.
love it up here though!
rybike
So I've been having issues with my current beadlock setup, Little things like no balancing out and loosing the inner bead every now and then so I decided to upgrade.  :rockingout:
300k
#94
Quote from: 300k on February 11, 2018, 07:32:43 PM
that's hawt
Hawt?.....
THIS IS "HAWT"!!!    https://imgur.com/gch5gJY
.....and Bead Locks not required!!   :thumbs:
Gnarls.  :gap:
rybike
Quote from: Gnarly4X on February 12, 2018, 01:58:39 AM
Hawt?.....
Gnarls.  :gap:
Not sure what you guys are going on about  :ha_ha:
But just to clarify, still running bead locks as there defiantly required for serious snow wheeling  :rockingout:
Crocks
I get very serious in the snow at 5 psi, Without beadlocks. My third year on the irocks, yet to throw a bead.
Shambs old 85 runner http://board.marlincrawler.com/index.php?topic=52566.0
Since I've added, ARP knuckle studs, MC short throw, MC dual case mount. Arb front locker. Arb twin compressor, new rear seats and carpet
Quote from: rybike on February 25, 2018, 12:35:17 PM
My comment should be in the thread I started about too little or too much, but for me, 20+ years of 4-wheeling, I NEVER once popped a bead off a rim, and I NEVER once had a flat tire on the trail, I never had bead locks.   :blah:
Air down PSI was typically 10 lbs for rocks, and 4 lbs. for sand, snow, mud.  I had both my 86 longbed and my 85 standard cab in the sand dunes a half dozen times - duning hard with the rest of the crazies and NOT ONCE did I pop a bead.  Many snow-run and mud-run trips,  Mud tires were always mounted on 15" alloy wheels.   :gap:
Was I just really lucky? :dunno:
Gnarls. :gap:
rybike
#98
Hey fair enough! I probably should have phrased that a bit differently, you are right they really aren't required for most guys. Half of our group doesn't run any sort of bead retention, but they usually stay around 5psi and don't have a issue.
Now recently I've found my self breaking trail most of the time and 5psi wasn't cutting it. Towards the end of last winter I was messing around with 0-3psi and as you can see on the last two pics of post #66 I did manage to drop a bead, but that was defiantly the lower end of the spectrum. But on that same note if you carry the tools and have the abilities to re mount a tire, why even add the extra weight of the bead lock? I guess I really like the piece of mind
Quote from: Gnarly4X on February 26, 2018, 02:18:18 AM
Gnarls. :gap:
It depends so much on the particular tire and rim.  I have had bias swampers that would roll off in the mid teens and my goodyears would stay on my 8" steelies at 2 psi.
Cheesemaker
And the the bead lock on wheels.  Some are more pronounced than others.  When I worked at the tire shop, some wheels took alot of PSI to seat a bead.  Others not so much.  You could tell by the "POP" on which wheel had a higher bead lock.
I remember when Hummers were all the rage, and we used to get calls out to Sandlake all the time.  Cause their Hummer rolled a bead, and the central air couldn't air up the tire.  16.5" wheels don't hold a bead very well.
rybike
And seems I cant leave it well enough alone...  :hammerhead:
redneckcustoms13
01 double cab hunting truck
06 tacoma street truck
rybike
Quote from: redneckcustoms13 on February 27, 2018, 08:04:08 PM
3rz swap, axle truss, hydro assist?
I still don't plan on adding a truss and hydro assist isn't in the picture quite yet. But I've been running my spare stock birf since my chromo broke, so I'm replacing that and freshening up the rest of the axle. The 3rz is going in and its a bit heavier so I'm adding a leaf and re working a few other things in the front
rybike
So this was my big reason for pulling the axle. My steering links have been hitting the frame at full bump and I didn't feel like welding it with a motor in, so what better time than now
Pass side capped in
plated both sides of the frame rail and painted, should have gotten pics before paint but I neglected to
The driver side I took even less pictures but you get the idea, the outside plate looks very similar
rybike
Got it back on all 4 wheels today, sitting a bit taller than planned but it will settle
joeyf
Looks good. Nice to see you didn't truss the axle. You don't need it, more times than not I have seen a good straight housing get warped after trussing it. You're knuckle gussets are all that is needed.
rybike
Quote from: joeyf on March 09, 2018, 08:53:31 AM
Agreed, I'm no engineer but the way I see it all of the forces are between the leaf spring and the trunnion
Now with the 3rz swap. I've been struggling with getting the motor mated to the trans, seems like 3rd time was the charm. My first attempt the trans was in place and I tried to bring the motor into it, But as you can see in the first picture I struggled getting the motor on the angle it wants.
Next attempt was dropping the trans and bolting the motor to the mounts, I had a buddy there to help me get the trans up but between the firewall clearance and the angle of the whole deal we just could not get them mated.
After struggling for awhile my old man got home from work and gave us the great idea to put them in as one, so out came the motor and trans again to get mated on the bench. It's a tight fit putting it all in as one with a uncut core support but it does go  :biggthumpup:
redneckcustoms13
Keeping the ps reservoir warm?
rybike
Quote from: redneckcustoms13 on March 11, 2018, 06:44:02 AM
I mean that rag on the reservoir doesn't do much, but I've found it just keeps a bit of the oil mess down  :dunno:
redneckcustoms13
rybike
Toy-only, I was a little weary of the chilkat ones after seeing people adding washers underneath
rybike
I guess I should update this, the 3rz has been running for almost a week now. I've been taking it back and forth to school about a hour drive away and it's been amazing, seems better on fuel than my 22re and the added power makes highway driving a breeze. Still have some loose ends to wrap up like cleaning up the wiring and finishing the exhaust, but that's easy enough
hows engine swaps in canada? regulated?
rybike
Quote from: THK Matt on March 23, 2018, 10:38:50 AM
Depends, We don't have smog checks so you can basically drop what ever in and get away with it unless you are issued a vehicle inspection. If that's the case the motor has to be newer than the original and equipped with all the factory emissions components
redneckcustoms13
Glad to see your still keeping that steering reservoir warm. Night and day difference between 22re and 3rz huh?
rybike
Quote from: redneckcustoms13 on March 23, 2018, 07:58:52 PM
All about a warm p/s reservoir in these cold Canadian winters  :gap: But ya I went into this not expecting much more than a semi modern efi system, as people like to say it's still a 4cyl. But I'm pleasantly surprised! Just what the truck needed, not to heavy, improved power and stock reliability
:)bestgen4runner
Question for You on Your winch.
What has been You experience with it, any issues?
How much have You used it?
I put one on My son's  truck and am curious.
I am 1/5th of Perfect Fit
rybike
Quote from: :)bestgen4runner on March 25, 2018, 10:02:58 PM
So I'd like to think I use it a fair bit, maybe not every week but once a month it seems to get a workout. I have had the solenoids get hot and the winch would only go in reverse, that was after a long day of winching. I do plan of switching to a albright solenoid but other than that I don't have any issues with it
