I'm a little late to the party but on the topic of triple sticks, the floor board modification is why I really don't want to go with raddesigns triple stick. Davez is designed so the linkage connects at the bottom of the stick below the pivot point. Though it doesn't change the shifter position for the 2 and 4 engagement Sent from my iPhone using Tapatalk
Good luck getting those.
I can't justify buying something that allows me to not cut my interior but still have to cut the floor. Sent from my iPhone using Tapatalk
To bad they font make an optional way of connecting to block, maybe keyed with 180° placement points
$150 for something I still have to fab some stuff on? I can't justify the price then I'm picky Im know. Sent from my iPhone using Tapatalk
Eh I already have my home made one in the works. I think I'm 30 in to it for the entire rear plate and the linkage. Haven't bothered with the front plate yet but it's not exactly make.Sent from my iPhone using Tapatalk
Holy crap that's really $150?! Yeah, I think I can buy some lengths of round tubing, solid bar stock, square tubing and a 3/16ths plate for about $40. Add $25 for the links and all thread... Sent from my LG-H830 using Tapatalk
Ya. I'll make sure I do a full write up on making my own after I get it done don't really want to do one before its done that way people aren't waiting on the info. I know I've rear through threads on that and I absolutely hate it when it on something small like that. A build thread I can enjoy ya....Sent from my iPhone using Tapatalk
As compared to davez (yes I know he's been out of stock for a long time) where the tab goes down and faces away from the body and has the linkage running below the bodySent from my iPhone using Tapatalk
What I see is a lot of nuts and arm ends that WILL wear out, if you use them anyway. My stock shifters will never fail to work.As far as the use of the crawl box, I use mine backing out of the driveway, parking at the store and when I hook to my trailer for a load of whatever. and never engage the front drive shaft giving me 3 or 4 extra gears to get my load moving.
I agree it does add more complexity and wearable components to shifting the tcase a as compared to just wishing a stock j shift but for me it's not an option to cut any part of my floor or interior out.. Where the rear shifter would go currently has the switches for my rear window (87 4Runner) as well as the relays for my elocker (which I really don't want to rewire) so triple sticks is the way to go for me. There is a part of me that wishes I had a pickup that I could just cut into but alas, not what I have.
solid thread for entering the dual case world. was helpful to read through and get the basic theory behind it all. in terms of triple sticks, in what scenarios have you found them most helpful? Personally I feel like I have more than enough choices in gearing that I'm unclear on how I would be able to utilize the third stick
Triple sticks doesn't exactly give you more gearing options, other than splitting up the high low and four-wheel drive two wheel drive single Jay configuration. It's more for convenience so that you have your shifters further forward
So along the lines of having shifters further forward, have others ran into the issue of knocking your front case out of low when putting the tranny into fourth gear. My front case stick sits exactly where 4th gear is. Can the short throw shifter help eliminate this?
How do you have your front cases stick mounted? It's a dog leg shifter (on mine at least) so if you remove the shifter and re install it 180* that should move where the shifter sits.Sent from my iPhone using Tapatalk
Started by Kurlee Daddee Toyota Pickup/4Runner Tech 1979-95
Started by nosnorb_808 General 4WD Discussion
Started by 4runnin_87 Project Research and Build-Ups
Started by chromewontgetyouhome Engine
Started by h8z2luze Newbie Questions
