Author Topic: 1200lb Clutch question  (Read 6397 times)
Tay85Runner
  • Member since Jul '16
« on: Jul 07, 2016, 02:13:36 PM »
I received my 1200lb clutch kit for my W56 and with it came the input shaft for the transmission... Do I need to change that out or if the one already in the transmission is good can I just keep using that one? Any help would be much appreciated... Thanks
  • Online Silver Turtle Award
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Re: 1200lb Clutch question
« Reply #1 on: Jul 07, 2016, 02:21:53 PM »
you sure that's not the clutch alignment tool
Tay85Runner [OP]
« Reply #2 on: Jul 07, 2016, 02:28:38 PM »
imdont think so if it is its one I have never seen before. It looks exactly like the input shaft and made out of the same metal it has a gear and what looks like a sprocket at the base. If I have enough posts I would put up a picture
  • Male Posts: 3,522
« Reply #3 on: Jul 07, 2016, 02:30:51 PM »
I don't think that comes in clutch kit, somebody must have accidently dropped it in your shipment
Tay85Runner [OP]
« Reply #4 on: Jul 07, 2016, 02:32:40 PM »
Yeah that's what I was thinking I just googled it and it is the input shaft... I counted the teeth and the have the same amount just figured I would ask... I would really hate to take the trans back out and apart... Thanks for the help
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #5 on: Jul 07, 2016, 05:37:29 PM »
You could always use it as a clutch alignment tool..............
 :think:
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,252
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #6 on: Jul 08, 2016, 04:33:58 AM »
You should not have to change the input shaft unless it's damaged, worn badly, or bent.  I agree with O, input shafts are NOT typically part of new clutch kit.
So, you already have the tranny into the bellhousing?  I guess I'm wondering why you would ask the question AFTER you already put the tranny back in?  Mechanic's remorse? :confused:
Tay85Runner [OP]
« Reply #7 on: Jul 09, 2016, 03:44:38 AM »
Gnarls- No I have not hooked the tranny back up to the motor yet... The motor is still on an engine stand... I read to change that input shaft you have to disassemble the tranny that's what I meant by I don't want to take it back out as I just put it up in the frame with supports... When I ordered the kit I thought I was just getting a clutch and then that part came with it so I wanted to check before I put the motor back in... Thanks again for all the help everyone...
  • Male Posts: 4,252
« Reply #8 on: Jul 09, 2016, 03:54:38 AM »
Hi T,
OK, sorry I misread your statement " I would really hate to take the trans back out and apart.."  that you may have already installed the tranny??
Have you done a clutch job before this one?
Tay85Runner [OP]
« Reply #9 on: Jul 10, 2016, 05:43:11 AM »
Gnarls- I have helped with clutches before but this is my first clutch job on my own and in this 4Runner... So I am still learning things along the way... I have a FSM to go by for most things and ask as many questions as possible...
  • Male Posts: 4,252
« Reply #10 on: Jul 10, 2016, 07:19:04 AM »
Hi T,
I'm just curious, what clutch kit did you buy?.. Brand and source?
Thanks,
Gnarls.  :spin:
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #11 on: Jul 10, 2016, 09:58:13 AM »
Does the part look like this?
Then it is a clutch alignment tool.  https://www.marlincrawler.com/hardware-tools/tools/clutch-disc-alignment-tool
But if it looks like this, then you do have the W56 input shaft.
I would be leaning on the alignment tool.
Tay85Runner [OP]
« Reply #12 on: Jul 13, 2016, 11:58:48 AM »
Gnarls - I bought the 1200lb clutch I bought it from Marlin Crawler as a kit.
Cheesemaker - the extra part I have is the second pic that you posted. Thanks for uploading that as I don't have enough posts to put up pics yet. I am not sure why I got the W56 input shaft I was going with Gnarls and figure that it just got shipped to me on accident.
thanks again everyone for the help hopefully I will be putting the clutch on and the motor back in this weekend.
  • Male Posts: 3,522
« Reply #13 on: Jul 13, 2016, 12:04:27 PM »
have you contacted MC regarding extra parts?, there probably some guy waiting to fix his truck
  • Turtle Points: 1174
  • Male Posts: 5,057
  • Crawlin with Marlin
« Reply #14 on: Jul 13, 2016, 02:58:32 PM »
They were probably "out of stock" after inadvertent shipping this one.
  • Male Posts: 4,252
« Reply #15 on: Jul 13, 2016, 05:12:37 PM »
...  hopefully I will be putting the clutch on and the motor back in this weekend.
Thanks T,
I'll be installing my tranny & t-case back in hopefully within a couple weeks.  Would you mind explaining your exact procedure starting with prepping the tranny and installing the pilot bearing, aligning the clutch disc, bolting on the pressure plate, sliding in the input shaft through the clutch disc, etc, etc.??
Thanks,
Gnarls.  :spin:
  • Male Posts: 3,522
« Reply #16 on: Jul 13, 2016, 05:37:09 PM »
For removing pilot bearing, I use bread, yeah, that's right bread. I've cut off the square part of a 3/8 extension. Pack hole in pilot bearing with bread, then tap cut extension into hole, and repeat, it will eventually push pilot bearing out, easy clean up too
Tay85Runner [OP]
« Reply #17 on: Jul 13, 2016, 06:30:47 PM »
Gnarls - yeah once I get it in ill post something up or I will send you a PM... I plan on using the FSM/the install procedures on Marlins website/then top all that off with buddies and beer... But yeah as I said I'll post something up with pics and lessons learned...
  • Male Posts: 4,252
« Reply #18 on: Jul 13, 2016, 07:49:18 PM »
Hey o,
Bread??... just curious....??.... French, Rye, Potato, Whole Wheat, Multi-Grain, Oak Nut,....??... OHHHHH.... I know!.... Wonder Bread!!
So my pilot bearing inside diameter where the tip of the input shaft slides into is .472".  My Craftsman 3/8" socket extension is .464", so the difference is .008", will that be tight enough tolerance to pop out my P-bearing?
I've read posts by guys who have used that method with grease.  My last clutch job I used a little pilot bearing puller and it would just barely pull it out.
It's not that I don't believe it's possible, I'd just like to see a video clip, or in person, demonstrating the hydraulic method of removing a pilot bearing.
Gnarls. :spin:
« Last Edit: Jul 13, 2016, 08:02:56 PM by Gnarly4X »
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #19 on: Jul 13, 2016, 08:49:56 PM »
Ive always soaked strips of newspaper in water and hammered it in with a bolt.  Same concept as the bread method and works good
  • Male Posts: 3,522
« Reply #20 on: Jul 13, 2016, 09:06:33 PM »
Hey o,
Gnarls. :spin:
I use whatever bread is available
Tay85Runner [OP]
« Reply #21 on: Jul 16, 2016, 03:15:20 AM »
Just as a heads up got an email from Marlin Crawler about getting that input shaft. They told me to just keep it and use it as an alignment tool if I wanted to. So I will prob just throw it on a shelf with other random spare parts I have for the 4rnr...
  • Male Posts: 4,252
« Reply #22 on: Jul 17, 2016, 06:33:34 AM »
Hey Tay85Runner,
Have you lubed up that old input shaft and slid it in yet?
Gnarls.  :spin:
« Reply #23 on: Jul 25, 2016, 10:32:40 PM »
I have used oily blue shop towel crammed in the pilot bearing. it works best I think with grease though.
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
« Reply #24 on: Jul 29, 2016, 04:25:10 PM »
I use an input shaft as a clutch alignment tool, only because I dont have an alignment tool, and I do have an input shaft
Last post Dec 27, 2003, 10:13:48 AM
by 79coyotefrg
Last post Jul 19, 2005, 02:40:50 AM
by mr4x42u
Last post Mar 04, 2006, 01:34:38 PM
by olemisstoy88
Last post Mar 11, 2008, 02:39:25 PM
by OOPS
Last post Feb 07, 2013, 11:50:28 PM
by zorak
