The build with no name.
Started by zippo, April 19, 2016, 11:07:30 PM
OVRAROK
Quote from: LittleSteve on May 29, 2016, 02:34:52 PM
Ill still never cut a bed.
You can always buy one that's bobbed, a trail bed
blackdiamond
I am pretty sure Marlin said the same thing!
emsvitil
How do you sleep in a shortened bed?
:headscratch:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
blackdiamond
Quote from: emsvitil on May 29, 2016, 04:32:23 PM
:headscratch:
Technically, my 85's bed was close to a queen bed in outside dimensions so dropping the tailgate should have been close to workable. It was about 13 in shorter than extended cab bed.
zippo
Im planning to mount a fuel tank, spare tire and high lift in the bed. I won't be sleeping in the bed.
If you see it, its for sale.
LittleSteve
Quote from: blackdiamond on May 29, 2016, 04:00:27 PM
Ah well theres cutting and theres trimming, two different things my friend
Refusing to fit in or comply.
Easy is not worth anything.
zippo
What does everyone think about running a slush box in a first gen?
As much as I was a 2jzte, they are just too long. So thinking a 1 or 2uz and keeping the auto?
blackdiamond
Quote from: zippo on June 11, 2016, 10:27:45 AM
Automatics work great off road, it's just a different driving technique.  Definitely no need to run ultimate gearing with one. I don't know how durable they are off road.
Rockcrawlintoy
Quote from: blackdiamond on June 11, 2016, 12:16:37 PM
they are fine if done correctly
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
helipilot77
Nooooooooo! Automatics have no place in a first gen.  :smack:
LittleSteve
blackdiamond
Quote from: helipilot77 on June 11, 2016, 02:07:35 PM
I get the question now...
Rockcrawlintoy
I approve of the auto. Properly set up of course. will be sick
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
RATCATCHER38
What auto would you run behind the 1UZ? Just wondering what adapters are out there for and auto conversion.
zippo
Quote from: RATCATCHER38 on June 12, 2016, 03:30:02 PM
So the 1uz comes with a a340e 2wd auto. You can rebuild it with the output shaft from a a340f converting it to a 4wd that will work with the factory ECU. Then marlin and a few others make adaptors that will take it to a RF1A tcase and your done.
RATCATCHER38
Ah good stuff! Quite straight forward then. What is the a340e like as an offroad box? Can you manually select gears?
Sent from my HTC_M9u using Tapatalk
LittleSteve
Quote from: RATCATCHER38 on June 12, 2016, 04:08:51 PM
Try RADesigns... He does a manual shifter/ecm for them.
zippo
Quote from: LittleSteve on June 12, 2016, 04:18:25 PM
Nice link!
helipilot77
He's on the board and lives in Clarkton, WA. R. DesJardin is his screen name.
http://board.marlincrawler.com/index.php?action=profile;u=10218
LittleSteve
H8PVMNT
While I agree that an auto in a 1st gen seems like blaspheme, if it was behind a 1UZ what am I going to say?  It might keep your 1UZ from twisting everything off too which would be a bonus.
– Steve McQueen
LittleSteve
Quote from: H8PVMNT on June 14, 2016, 07:22:47 AM
Depends in the driver.... You can feed the power in gently, the uz does not have a snappy power delivery its very smooth.
The R series of transmission are rated for the power...
zippo
So I got all moved. wired my welder in.
And started getting the shop in order. Got the bottom of the work bench built. 3" Schedual 80 steel pipe, 2x3x3/16 box tubing. The top will be 3/4" steel plate. Little Steve welded half I welded the other.
OTO Phil
What height did the top end up at?
Sent from my LG-H830 using Tapatalk
zippo
#85
Quote from: excabswap on September 18, 2016, 11:02:37 PM
42", I am rather tall and is a really nice height. It is also adjustable. I could drop it down a little over an inch and up prolly 3 inches.
Slabzilla
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
zippo
So RockcrawlinJK came over today and helped me start building a barn. 16.5'x12' Front is 10' tall rear is 7'
The posts are 6x6 tamped in the dirt. You know when you tamp enough when you don't have enough dirst to fill the hole. I rented an auger. Well worth the money. Dug the hole in just a few min.
Diggin this out of a hole 2' underground sucked
I still need to cut the tops off
A Good days work!
John Doe
What are your plans for steering? Have you looked at the new Keyed steering arms from Front Range off-road?
zippo
