Author Topic: Engine Removal  (Read 2779 times)
sparkynacho
  • Turtle Points: -7
  • Member since Jan '07
Engine Removal
« on: Jun 20, 2010, 04:36:39 PM »
Well I guess I have to remove the engine out or the 4Runner. How do I remove it without the head on? I don't want to damage anything
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
Re: Engine Removal
« Reply #1 on: Jun 20, 2010, 04:38:06 PM »
bolt the chain to the block sides
Early
  • Turtle Points: 67
  • Male Posts: 470
  • Member since Oct '09
  • The Buddhas ridin shotie
Re: Engine Removal
« Reply #2 on: Jun 20, 2010, 04:49:20 PM »
don't forget to unbolt it  :biggthumpup:
I chained the motor mounts and strapped the rear to keep it level. i wasn't in the air long at all though.
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
71Dart
  • Turtle Points: -1
  • Male Posts: 31
  • Member since Jun '10
  • 89D Army Strong!
Re: Engine Removal
« Reply #3 on: Jun 30, 2010, 09:59:47 PM »
Just bolt the chain to the block on opposite corners using the head bolts it will be good to go!
89D EOD  ARMY Strong!!!
Early
  • Turtle Points: 67
  • Male Posts: 470
Re: Engine Removal
« Reply #4 on: Jul 05, 2010, 04:11:43 PM »
i've got no proof what-so-ever, but i don't think I would do this.
hrm.... do you have a lift? yes do as stated above. no, take as much as you can off it (a/c, Alt brackets, motor mounts if you can, flywheel clutch)  and pull it out. done it, your backs gonna hurt a bit though.
or may be to late.
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: Engine Removal
« Reply #5 on: Jul 05, 2010, 05:59:54 PM »
I think headbolts are the best way to life when the heads are off. If you have bolts you are going to replace. I have alway seen when lifting by the sides of the block with the head off, the chain rubs the edge of the block to head surface, causeing it to form a ridge which will need to be tended to. If you are able to get around this with a engine level go for it, but head bolts are good to go.
If you see it, its for sale.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Engine Removal
« Reply #6 on: Jul 08, 2010, 09:58:27 PM »
:ack:  ive never used the head bolts but i have used a couple short bolts (main bearing cap bolts from a junk engine) actually in the headbolt holes
ive also used lift tabs made to bolt into 10mm holes on the block and run a chain thru the large end
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: Engine Removal
« Reply #7 on: Jul 09, 2010, 09:53:59 AM »
Take a couple old head bolts, heat them up and form a loop at the top.  Now you have lifting eyes  ;)
Last post Apr 08, 2005, 01:00:39 PM
by BamaToy
Last post Feb 26, 2007, 09:34:10 PM
by Wermz84
Last post Aug 05, 2007, 11:36:17 AM
by Ewong
Last post Apr 27, 2008, 08:33:24 PM
by Cheesemaker
Last post Aug 29, 2010, 05:29:49 PM
by pumkin toy
