Turn key ready to wheel buggy.
Belly 21"
Top of roof 72"
Width 54"
Wheelbase 107"
Outside tire to outside tire 78"
Engine
22RE Complete new longblock with about 4 wheelin trips. Hand made header with supertrap muffler.
Frontend
Toy housing with dana 60 outers from a Ford F-450 New ball joints. Diff is a hy pinion 529 gears ARB locker. Wilwood brakes.
Rearend
Trailgear Rock Assult housing with moser cromo full floating axles. Diff is a V6 529 gears ARB locker. Gears have one run on them.
Trans & t-cases
G52 trans Duel t-cases with 4.7 gears in rear case. Bobbylong cromo output shaft.
Suspension
Bunk cromo links with new Jonny Joints F&R. Panhard bar and rear upper links are aluminum. Fox 16" air shocks all around.
Steering
PSC full hydro setup
Tires and wheels
17" TrailReady duel beadlocks with 39" BFG sticky Krawlers.
Stereo
Alpine head with radio and I-Pod controls, Alpine 500 watt amp, 4 Focal speakers, RockFord Fossgate amp.
Misc.
Corbeau Baja SS seats with Crow 3" belts
Aluminum rear mount radiator
10 gallon fuel cell with AN fitting and aircraft fuel lines.
Tilton pedals with seperate master cyls.
Pretty much everything on this rig has been rebuilt or replaced in the last two years.
I'm 20 miles north of Seattle WA. My # 425 830 8657
$16,000 or $13,500 with out tires and wheels.
May consider some trades up or down. Would be interested in 66-72 Chevelle, 67-69 Camaro, 67-72 mopars. Built TJ or solid axle Taco.
