Author Topic: HD birf seals  (Read 2632 times)
dalton
  • Member since Oct '09
HD birf seals
« on: Oct 18, 2009, 06:34:35 PM »
I'm getting ready to do seals and bearings in my 85' are marlins HD seals worth it?  :dunno:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: HD birf seals
« Reply #1 on: Oct 18, 2009, 07:40:01 PM »
:thumbs: worth every penny
Marlins knuckle rebuild kits are top of the line KOYO bearings, (same as Toyota used when the trucks were made in japan)  and the Eco seals are like no other  http://board.marlincrawler.com/index.php?topic=32224.0
http://marlincrawler.com/axle/front-axle-parts
Re: HD birf seals
« Reply #2 on: Oct 18, 2009, 07:46:02 PM »
Skinny_Pedal
  • Turtle Points: 89
  • Male Posts: 2,833
  • Member since Apr '04
  • work so I can support my lifestyle
Re: HD birf seals
« Reply #3 on: Oct 18, 2009, 09:12:27 PM »
absolutly worth it. And when you blow a birf they dont rip to shreds. If something is cheaper there generally ia a reason :twocents:
Im an OG
drayday55
  • Turtle Points: -1
  • Male Posts: 299
  • Member since Feb '09
Re: HD birf seals
« Reply #4 on: Oct 18, 2009, 09:21:03 PM »
get them they are cheap!  and only slightly more than crap ones
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: HD birf seals
« Reply #5 on: Oct 19, 2009, 10:05:31 AM »
Yes, are very forgiving if the knuckle is not centered correctly.
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
Re: HD birf seals
« Reply #6 on: Oct 20, 2009, 12:24:04 AM »
worth every penny.    :biggthumpup:
i love oregon wheelin.
86toyota
  • Turtle Points: 2
  • Male Posts: 353
  • Member since Nov '07
    • Montana 4x4 Association
Re: HD birf seals
« Reply #7 on: Oct 20, 2009, 10:07:54 PM »
Deffinatly worth it. Quality is always worth the extra  :twocents: !!
T86OTA
dalton [OP]
Re: HD birf seals
« Reply #8 on: Oct 20, 2009, 10:12:51 PM »
well I'm convinced i ordered my set today i have another question  where do you pull from on the knuckle with the scale to get the pre-load right and I'm assuming the same amount of shims from the top to the bottom?
Re: HD birf seals
« Reply #9 on: Oct 21, 2009, 06:51:50 PM »
if i remember correctly you use the steering arm,  yes keep the shims on the top and bottom as close to the same thickness as possible, this will get it at least close to center,   i recently learned having the sst gives you a perfect center but most people dont have access to one
OOPS
  • Male Posts: 2,561
Re: HD birf seals
« Reply #10 on: Oct 21, 2009, 08:11:18 PM »
Some good reading materal, 1985 front end section from the FSM;
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
dalton [OP]
Re: HD birf seals
« Reply #11 on: Oct 21, 2009, 11:25:26 PM »
thanks guys
Last post May 08, 2005, 07:35:06 PM
by Ferg
Last post Dec 09, 2005, 07:56:30 AM
by Jase
Last post Feb 26, 2007, 08:47:41 PM
by Lazy-Boy
Last post Mar 15, 2007, 03:29:36 PM
by Tallchevy
Last post May 02, 2009, 11:31:49 AM
by jeff94runner
