Reply #2 on: Jul 18, 2004, 09:40:59 PM »
Sealing the unit would trap the mositure that is found in the air in the ECU. This could in time cause internal corrosion. Also due to the heat, the ECU needs to breath.
How about moving it up higher if you are worried...thanks brainlessfool
![Green Grin :greengrin:](https://board.marlincrawler.com/Smileys/marlin/greengrin.gif)
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
