5 spd question
Started by sumedumbkid, April 18, 2003, 08:54:07 AM
sumedumbkid
how do i Identifiy a toyota 5 spd transmission and t-case in my buddys truck it a 1980  toy that came with a 4 spd and now its got a 5 spd and we need to figure out wich tranny it is pics would help if some one has some
THANK you
ERIC
1981 toyta 33" muds 33" custom lift  rear buggy springs and 56' chevys w56 5speed
84runner
#1
Ask Big Mike he would know I'm pretty sure.
Cracker
#2
First off, does it look like it has the bellhousing cast into the tranny housing, or is there a seam where it looks like they are seperate pieces?
Art
99 Taco
80 Hilux - 20/22R Hybrid, Dual Mikuni's, R151 trans, Budbuilt X-member
74 FJ40 "The Project"
#3
Cast Iron or Aluminum?
Seperate Bellhousing or non-removable bellhousing?
Single shifter on top or two?
4 bolt shifter base or 6 bolt shifter base?
Driver- or Passenger-side fill plug?
One piece or two piece release bearing?
21- or 23-spline output coupler?
Female or Male output shaft?
If its aluminum, is the center piece cast iron or (its's also) aluminum?
How many wire is the reverse/backup switch?
What's my name?
84runner
#4
You the man BIG_MIKE   :bowdown:
