Author Topic: p/s question  (Read 689 times)
82juguete
  • Turtle Points: 5
  • Member since Jan '07
p/s question
« on: Jul 03, 2007, 08:55:48 PM »
The power steering pump, reservoir, bracket, etc from a 91 22re should bolt right up to my 82 22r, right??? Converting my truck from manual to power steering is necessary to install my crossover steering right?  Is their even such thing as a non power IFS box??? thanks
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: p/s question
« Reply #1 on: Jul 03, 2007, 09:03:45 PM »
you need to convert to a IFS power steering box and yes, convert to a power steering setup if yours is not equipped....
the 91 stuff is different from your truck..... the pre85 brackets and pump were different than the 85 and later..... they do not bolt up to each other... their holes are just slightly off. you cant put a 84 pump in an 85 bracket... however if you have the pump and brackets from the same model year, their shouldnt be a problem with bolting it to the older block
i recently put an ifs pump on my sa truck, not because i didnt have a pump, but because i had no brackets, i got brackets from an ifs truck, and my pump wouldnt fit, so instead of getting other brackets, i used the pump that fit the brackets....
Last post Apr 20, 2003, 04:06:00 PM
by 84runner
Last post Jul 19, 2004, 03:13:47 PM
by robrocketanski
Last post Feb 27, 2005, 12:16:30 PM
by Weldo
Last post Apr 08, 2005, 07:16:22 AM
by mr4x42u
Last post Aug 24, 2006, 06:42:02 PM
by Ewong
