Author Topic: clutch question  (Read 1395 times)
olemisstoy88
  • Turtle Points: -381
  • Male Posts: 521
  • Member since Dec '05
clutch question
« on: Mar 03, 2006, 06:33:29 PM »
I dont have a drive shaft in my truck right now. I am trying to finish adjusting the clutch to get it to disengage. I cant get the clutch to do it. The speedometer reads a steady 15 mph. When I change gears and give it gas I cant go past 25 or it sounds like the motor is gonna blow. It doesnt act like it is in a gear. it just goes up to 15 when the truck is started in any gear. The clutch doesnt work yet or is it working but with out the shaft there is no resistance? Is that because there is no shaft in the truck, thus reducing the amount of drag on the transmission. or is my master cyl/ clutch out of wack?
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Re: clutch question
« Reply #1 on: Mar 03, 2006, 07:16:28 PM »
You need the drive shaft in the trans to keep the tail shaft from spinning. If there is no load on the tail shaft it will turn even if the trans is in neutral.
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
Re: clutch question
« Reply #2 on: Mar 03, 2006, 09:42:49 PM »
X2.  The drag on the synchros and bearings from the main shaft spinning all the time will cause the output shaft to spin regardless of gear position.  Stick the driveline in and then report back!
Ryan
olemisstoy88 [OP]
  • Male Posts: 521
Re: clutch question
« Reply #3 on: Mar 04, 2006, 01:34:38 PM »
thats what I figured. Will do
Last post Jul 19, 2005, 02:40:50 AM
by mr4x42u
Last post Apr 01, 2006, 07:14:34 PM
by GoaT
Last post Feb 07, 2013, 11:50:28 PM
by zorak
Last post Dec 30, 2014, 07:53:58 PM
by MatS
Last post Jul 29, 2016, 04:25:10 PM
by BoG-ToY
