Author Topic: PROJECT FAMLIY CRUSIER BEGINS  (Read 14273 times)
LCOwner
  • Turtle Points: 50
  • Male Posts: 302
  • Member since Dec '02
  • Have you seen his shop OMG!!!!
    • Cruiser Build-up page.
Re: PROJECT FAMLIY CRUSIER BEGINS
« Reply #30 on: Dec 16, 2005, 12:11:07 PM »
Are you going to part out the rest of the FJ60?
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
4THEWKN [OP]
  • Turtle Points: 226
  • Member since Dec '03
  • Mickey Bomb's Rock!
« Reply #31 on: Dec 16, 2005, 12:22:42 PM »
Yes what ya need.....Dean
Rock Rash: It's all mind over matter, if you don't mind it don't matter!!
LCOwner
  • Turtle Points: 50
  • Male Posts: 302
« Reply #32 on: Dec 16, 2005, 09:27:52 PM »
Parts from the gas filler neck, maybe more.  Your're in Fresno right.  PM me your phone number and I'll call you.
4THEWKN [OP]
« Reply #33 on: Dec 24, 2005, 05:51:01 PM »
Well started the teardown today. Woke up at 4:30am and couldn't go back to sleep :o  so I hit the garage.Here's some pic's.
Image hosted by Photobucket.com
The top of the fuel take looked this nice so I painted the bottom to match.
 I also removed the fuel sender to take a look inside. It looked as new as the top. I wasn't sure that the odometer was right at 78,000 but  when the Reg came it said 78,000. I still wasn't  sure but today I say something that comfirmed it I post Pic's of the hint that this is a low mileage Cruiser tomorrow.
I'm also having to change the bellhousing to a FJ40 bellhousing because their is no previsions for the bellhousing mounts. (Thanks CruzrDave)
Painted it up and it's ready to go on.
« Last Edit: Dec 24, 2005, 05:58:09 PM by 4THEWKN »
4THEWKN [OP]
« Reply #34 on: Jan 07, 2006, 07:14:24 PM »
Pulled the frt FJ60 housing down today. What a mess!! Burfield soup anyone?
CruzrDave and I have been talking about what to do about the perch problem. Because the spring perches have to be moved in 1.00" on each side to compensate for the narrower frame there is a problem. When you move the spring perch over on the passenger side of the axle the perch starts to move into line with the third member, so now the u-bolt won't go on with out hitting the third member. I've got a few ideas to remedy the problem. I'll post up some pic's of the problem latter..Dean
The end of the yardstick is where the middle of the spring is and the yellow mark is where the edge of the spring is.
« Last Edit: Jan 07, 2006, 07:33:48 PM by 4THEWKN »
Dooner
  • Turtle Points: 217
  • Male Posts: 769
  • Member since Feb '05
  • Invest in precious metal
« Reply #35 on: Jan 08, 2006, 09:10:17 AM »
Outboard man, Outboard! Though youd be loosing a wee bit of leverage on your springs
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
gotrocks
  • Turtle Points: 107
  • Male Posts: 2,653
  • Member since Dec '04
  • FLOOR IT!!
« Reply #36 on: Jan 08, 2006, 11:25:31 AM »
keep the pics coming, oh and I can't remember is the fj60 rear housing offset like the 40?
Weak-Link
  • Member since Dec '05
« Reply #37 on: Jan 08, 2006, 02:38:07 PM »
yes, both are offset
Last post Oct 28, 2005, 12:49:16 PM
by CruzrDave
Last post Dec 07, 2006, 06:20:12 PM
by Makohon
Last post Mar 17, 2007, 06:37:00 AM
by yota-tota
Last post Mar 20, 2008, 07:57:24 AM
by unclejpl4x4
Last post Jan 29, 2012, 11:20:44 PM
by bigarms23
