Author Topic: Bending brake lines  (Read 1485 times)
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
Bending brake lines
« on: Sep 01, 2021, 01:43:31 PM »
Not for for fabbing new ones.
Just adjusting them a little for clearance of the bolts on my new rock sliders.
How much give do they have?  I'm scared to break them.
I only need an inch more between the 2.  For now I used a bicycle inner tube to prevent chafing.
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
Wainiha [OP]
  • Male Posts: 1,170
Re: Bending brake lines
« Reply #1 on: Sep 04, 2021, 11:35:14 AM »
Any thoughts?
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
OVRAROK
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
« Reply #2 on: Sep 04, 2021, 02:25:15 PM »
I think they have a little give in them.. just have to be gentle about it..
I know that making your own with some of the new hard brakeline available is pretty darn easy..
OVRAROK
  • Male Posts: 3,522
Wainiha [OP]
  • Male Posts: 1,170
« Reply #4 on: Sep 04, 2021, 06:05:20 PM »
Mahalo.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
2G4R
  • Turtle Points: -16
  • Member since Sep '21
« Reply #5 on: Sep 08, 2021, 09:34:16 AM »
plenty of flexibility.  Just dont 'pinch' when you make the bends- hold with pliers and kink.  bend around an object for a round curve/ prevent kinks
Trindaddy
  • Member since Dec '21
« Reply #6 on: Jan 02, 2022, 08:55:48 AM »
Brake lines have been made of many materials over the years. Only rusty ones have no flexibility. A small bending tool could help you a lot or forcing around a round object as one posted suggested. Beware as you approach 45 degrees. That is where they tend to kink without a tool. Otherwise, you can bend them quite readily. 2 small bends are better than1 and so on. For the record, the new copper nickel alloy lines blow everything else away...even stainless.
Wainiha [OP]
  • Male Posts: 1,170
« Reply #7 on: Jan 02, 2022, 09:50:17 AM »
Thanks for the help members.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
a1gemmel
  • Turtle Points: 149
  • Member since Jun '21
  • Amateur shitbox whisperer
« Reply #8 on: Jan 02, 2022, 11:08:44 AM »
When in doubt just replace the whole run from end to end - the new copper nickel line is super easy to work with. You don't want to find out your line is compromised when you max out the line pressure in a panic situation and the pedal goes to the floor.  That being said, I am a patron of the salt states so my experience of brake lines snapping when you just look at them funny may not be universally relevant  :D
1981 Pickup - 37s, 5.29s, L52, dual cases 4.7 rear, e-locker front, grizzly rear, 22R stroker
1986 4Runner - 35s, 5.29s, auto, front Detroit, rear trutrac, 4" lift
maxreilly
  • Member since Mar '22
« Reply #9 on: Mar 28, 2022, 10:15:37 PM »
Im an electrician by trade.  So plumbing break lines for my truck projects was like building a miniature model.  Bending conduit or brake lines is easy.  For small changes just use your hands.  As you stated DO NOT KINK the line.  Brake line pliers/benders, look them up... You place the tube into a shoe that is the correct radius to bend the line for its diameter and hold the wall of the pipe perpendicular to the crease that will form in the pipe as you bend it.  PM me for more info
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
  • What is this Toyota you speak of?
    • Buy me some coffee
« Reply #10 on: Apr 12, 2022, 12:34:00 PM »
If you can't find a bending tool, use 3/8" sockets, variety of bend radii. Try to bend it once, not back and forth.
Assuming its factory line it should be steel and fairly easy going. Copper is worst for work hardening. Copper Nickel, also called Cupro Nickel and Kunifer is top stuff for workability.
Stainless is awesome but has its own individual set of problems
Refusing to fit in or comply.
Easy is not worth anything.
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,252
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #11 on: Apr 16, 2022, 05:18:25 AM »
Will braided brake lines work?  :dunno:
Gnarls. :usa:
Wainiha [OP]
  • Male Posts: 1,170
« Reply #12 on: Apr 16, 2022, 01:19:52 PM »
I think it's good now. I bent it a little and see no signs chaffing. I might buy a small bender just to stockpile tools.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
Last post Apr 21, 2006, 03:03:36 PM
by To The Floor
Last post Jul 18, 2006, 05:37:25 AM
by bluetoy84
Last post Aug 24, 2006, 08:42:25 AM
by gotrocks
Last post Jul 24, 2007, 06:39:19 AM
by my87toy
Last post Jan 02, 2008, 11:35:59 PM
by kneedownnate
