Author Topic: Rear end runs crazy  (Read 2069 times)
E YOTA
  • Male Posts: 690
  • Member since Jan '04
Rear end runs crazy
« on: Sep 06, 2013, 04:52:21 PM »
My 96 Tacoma rear end seems to b jumpin when I'm on the highway at a certain speed .... Not quite sure wat it is if its caused my no weight in the back or what??? Thanks
built lastnight, crawl today...
andeze
  • Turtle Points: -1
  • Male Posts: 51
  • Member since Jun '11
Re: Rear end runs crazy
« Reply #1 on: Sep 06, 2013, 05:08:53 PM »
Those big old iroks could be the problem. Put the rears up front and see if it follows.
E YOTA [OP]
  • Male Posts: 690
« Reply #2 on: Sep 06, 2013, 11:01:05 PM »
tried that ...seems like the rear end is too light ... my buddies truck does the same thing too...n he's running radials toyos....
daniresch
  • Turtle Points: 930
  • Male Posts: 761
  • Member since Apr '11
« Reply #3 on: Sep 07, 2013, 03:51:23 PM »
could consider verifying your driveline is balanced, and hows your pinion angle?
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Sep 07, 2013, 07:29:33 PM »
Does this happen on all roads or just certain stretches? I have hopping issues on the old sections of the I-110 from downtown L.A. to the I-105 and then on the I-10 towards Palm Springs.
E YOTA [OP]
  • Male Posts: 690
« Reply #5 on: Sep 08, 2013, 08:22:12 PM »
no it happens when i reach a certain speed on the highway...and yes my driveline is balanced and the angle is good...when my truck was stock length it did the same thing now i've bobbed it 25" and its still happening. had the driveline redone just to make sure it was balanced well. im just thinking its jus too lite back there
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
    • Buy me a soda
« Reply #6 on: Sep 08, 2013, 08:49:20 PM »
Try pulling the rear shocks and see how it feels.   I think the bilsteins that TG sells are valved too stiff for the rear of a Toyota. Mine seems to do the same thing until I toss a bunch of weight in the bed.   I recently moved my rear shocks around so they were at more of an angle and it seemed to help a little.
  • Momentum Man
  • Lego Enforcement
« Reply #7 on: Sep 08, 2013, 09:09:13 PM »
That was going to be my next suggestion and maybe springs. I can't tell from your avatar but are you still IFS or SAS'd? I had to soften the front on my 4Runner IFS, the stiffer front was causing some front bounce when I put the softer rear springs.
Last post Nov 13, 2004, 03:19:24 PM
by 4bGaz
Last post Sep 10, 2005, 02:28:21 PM
by RHG
Last post Dec 18, 2005, 03:38:24 PM
by 79coyotefrg
Last post Jun 09, 2006, 11:45:13 AM
by CTENG in KS
Last post Jan 19, 2016, 07:27:26 AM
by Mudder
