crazy rear disconnect Idea
Started by 4bGaz, November 12, 2004, 05:30:49 PM
4bGaz
not sure if this has been mentioned but just say you turn the front and rear diffs upsidedown and run the engine and gear box in the rear so the front diff becomes full time 2wd,And run a high pinion in the rear so it becomes a low pinion and run the twin stick conversion so it now becomes like rear diconnect :crazy: :haha:
cruzila
Prismo
It would be weird with the shifter pattern reversed & dual cases. I have enough trouble figuring out what gear I am in now lol
kyle_22r
why not just flip both diffs?  if you use a high pinion in the rear with a flipped drivetrain you'll still go backwards :_order:
i think this has been done on some buggies with ford 9" axles
4bGaz
Quote from: kyle_22r on November 12, 2004, 06:39:27 PM
AHH,I metioned run the high pinion in the rear then flip the diff it so it will be a low pinion for strength :wave:
4bGaz
Quote from: cruzila on November 12, 2004, 05:34:15 PM
Easier to turn the seats around :hammerhead:
Because then you have steering probs unless you run hydro 4 wheel steer :smack:
