I had a vibration only around 25 mph and when I had a load in the truck, I had no vibration. So I thought it had to be the older u-joint (replace one already two years ago). .............. but now I have the faint vibration at higher speeds that I didn't have before. The vibration is typical rythmic sound that you hear when a u-joint is going bad.Any thoughts or ideas what might be causing this? Bad u-joint, bad instalation? Thanks
probably the joint you replaced 2 years ago
or they didn't align the joints when they put the driveline back together (splines, ears)
yeah thats what i meant when i said its possible they made it out of sync
thats what i thought, just cleared it up a bit.
I'm not sure, I know there are white paint marks on mine. I will check out my ears.
Started by Yota87Truck « 1 2 3 » Rig Gallery
Started by weirdtimes_7 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by norcalblake Toyota Pickup/4Runner Tech 1979-95
Started by dweinberg01 Toyota Pickup/4Runner Tech 1979-95
Started by Plainview Suspension
